Determining if a matrix is diagonalizable with explanation
  • Thread starter Thread starter LinAlgStudent
    Explanation Matrix
The matrix provided is a 5x5 upper triangular matrix with a single eigenvalue of 2, which has a multiplicity of 5. It is concluded that this matrix is not diagonalizable because it lacks the requisite five linearly independent eigenvectors; instead, it has only one non-zero eigenvector and four zero vectors. The matrix is in Jordan Canonical Form, indicating that it cannot be transformed into a diagonal matrix.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with matrix diagonalization concepts
  • Knowledge of Jordan Canonical Form
  • Ability to perform row reduction on matrices
  • Study the process of finding eigenvalues and eigenvectors for matrices
  • Learn about Jordan Canonical Form and its implications for diagonalizability
  • Research the relationship between the dimension of eigenspaces and diagonalizability
  • Explore methods for row reducing matrices to determine diagonalizability
Students studying linear algebra, particularly those focusing on matrix theory, eigenvalue problems, and diagonalization techniques.
LinAlgStudent
Determine if this matrix is diagonalizable and explain why or why not.
[ 2 1 0 0 0 ]
[ 0 2 1 0 0 ]
[ 0 0 2 1 0 ]
[ 0 0 0 2 1 ]
[ 0 0 0 0 2 ]
No equations provided and the use of a calculator will be prohibited on the test, so that's out of the question. I can find the determinant via expansion, but that doesn't help really.
So I'm pretty confident that this is not diagonalizable because the only eigenvalue seems to be 2 with multiplicity 5, although I'm not sure that actually proves anything. Additionally, I'm fairly certain that because the study guide has this as a 5x5 matrix with calculator use prohibited, there must be a way, just from the shape, to determine whether it's diagonalizable. Does anyone have any tips?
Thank you so much for any help!
One trick is to just take the matrix you have and row reduce it until you have only diagonal entries left. If you can do that, you have a diagonalizable matrix.
it row reduces to the identity matrix. Is that indicative of anything specific?
Got a reference for that?? I don't think what you say is true...
The best way to do this exercise is find the eigenvectors and see if they span the space.
So I've found all eigenvalues to be equal to 2, the first eigenvector i think is:
[1]
[0]
[0]
[0]
[0]
and the other four all all 5x1 zero vectors.
But what does that mean in the context of the question?
[ 2 1 0 0 0 ]
[ 0 2 1 0 0 ]
[ 0 0 2 1 0 ]
[ 0 0 0 2 1 ]
[ 0 0 0 0 2 ]
The matrix (A) above is the matrix representation of a linear transformation T with respect to the basis e_1=(1,0,0,0,0),...,e_5 = (0,0,0,0,1). If a transformation (i.e., a matrix) is diagonalizable, its matrix becomes diagonal when re-expressed in some other basis f_1, f_2, f_3, f_4, f_5. Since two similar matrices have the same eigenvalues, the "diagonal" would need to be 5 times the identity matrix, and that means that the f_i would have to be eigenvectors of T (i.e., of the matrix A). In turn, that means that there must be 5 linearly independent eigenvectors. You can determine the eigenspace of A and check whether its dimensionality is 5.
RGV
RGV
Provided that all the eigenvectors of A are zero vectors save for one of them which has only one nonzero entry, wouldn't that suggest that the eigenspace of A is only 1 dimensional? So, in order for A to be diagonalizable, the eigenspace would have to be of dimension 5, but it is of dimension 1 so it is not diagonalizable?
For further exploration, research Jordan matrix and generalized eigenvector.
Yes, because of what I know, I see that it is in Jordan form, and so it is "as close to diagonal" as it will ever be.
I also like the method explained above, find the eigenvectors for the sole eigenvalue, "in the end there will be only one."
(The zero vector is never called an eigenvector, otherwise it would always be one, A0=λ0, though eigenvalues can be zero. )
Zero vectors do not count as eigenvectors (essentially by definition), so the eigenspace is, indeed, one-dimensional. So, YES: the matrix is not diagonalizable.
In fact, the matrix is already in its Jordan Canonical Form, and that consists of a single Jordan block of dimension 5. A diagonalizable matrix would have to have a diagonal Jordan Form.
RGV
Yes, I was mistaken; I thought I'd uncovered a quick way to work the problem.
