Determining if a series converges
4 replies · 2K views · last reply
Sunwoo Bae
Does the following series converge? Give reasons. (Series shown below)
None
Handwritten solution to a series convergence problem using the limit comparison test, comparing the terms 5^n/(4^n+3) with (5/4)^n and concluding the series converges, with a boxed final statement and a geometric series sum of -5 circled.
The following is my attempt at the solution.
Here, I used limit comparison test to arrive at the answer that the series converges.
However, the answer sheet reads that the series diverges.
I am confused because I cannot figure where my work went wrong…
can anyone tell me how the series diverges, and why my work is incorrect?
Thank you!
The geometric series with terms ##(\frac 5 4)^n## clearly diverges. The formula for a convergent geometric series does not apply. And, in particular, the sum of the series in not ##-5##. That would be too absurd!
Got it! Thank you!
As opposed to just absurd enough? :wink:
Sunwoo Bae said:
Homework Statement:: Does the following series converge? Give reasons. (Series shown below)
Relevant Equations:: None
In your work for the Limit Comparison Test, you arrived at a limit of 1. Your mistake was not realizing that ##\sum \frac {5^n}{4^n}## is a divergent series. Since the limit you calculated was positive and finite, the series you were working with had the same behavior as ##\sum \frac {5^n}{4^n}##.
Another test that is sometimes useful is the Nth Term Test for Divergence. Since ##\lim_{n \to \infty} \frac {5^n}{4^n + 3} = \infty## (work not shown), then the series ##\sum_{n \to \infty} \frac {5^n}{4^n + 3}## diverges. Any time you get a limit that isn't 0 or fails to exist in this test, the series diverges.
