Determining Mass from Orbital Period and Radius
The discussion revolves around determining the mass of a planet based on its orbital period, radius, and velocity. The context is set within celestial mechanics, specifically relating to circular orbits.
  • Participants explore various equations, including gravitational force and centripetal acceleration, while questioning the relationships between period, radius, and mass. Some express uncertainty about the necessity of the star's mass and the applicability of energy-related equations.
There are multiple lines of reasoning being explored, with some participants suggesting the use of the vis viva equation and Kepler's laws. Guidance has been offered regarding known quantities, yet there remains a lack of consensus on the best approach due to the missing mass of the star.
Participants note that the mass of the star is not provided, complicating the calculations. There is also a mention of the problem being related to a specific case known as "Hot Jupiter," which may impose additional constraints or assumptions.
procon4
What is the mass of a planet (in kg and in percent of the mass of the sun), if:
its period is 3.09 days,
the radius of the circular orbit is 6.43E9 m,
and the orbital velocity is 151 km/s.
I'm unsure what formulas to use, though these seem relevant.
F= ma
accel. centripetal = v^2/r
Total Energy = -G*(mass of planet)*(mass of sun)/2*radius
I thought I should use Force of gravity = mass of the planet times the centripetal acceleration, but the mass of the planet cancels out. I can't ID the right relationship between the period, radius and mass, so I'm not sure what to do.
Thanks for any help.
JS
Consider using vis viva equation as applied to circular orbits
That's a really good suggestion--I'm surprised that equation isn't in our textbook. The problem is that the mass of the star around which the planet orbits is not given. So I guess there must be some relationship between period, orbital radius, and mass, but I'm not sure what it is.
I would have expected an energy-related equation could work, but I haven't found one that doesn't either require the star's mass or in which the mass of the planet doesn't cancel out.
The mass of the sun is a known quantity which you can lookup. You could derive vis viva from what the question gives you though...
edit:I don't think you even need the period TBH
Use Keplers law of period and the mass turns out to be 2.207610x1030
110% mass of the sun.
You can also use orbital velocity and work it out from there.
So just to clarify the situation here, the star at the center of the planet's orbit is not the sun. But another problem was that I needed to find the mass of the star, not the planet. To do that, I just used the F=ma equation, with F being the force of gravity, m being the mass of the planet, and a =v^2/r. The mass of the planet cancels out and you're left with the mass of the star.
The answer fcb posted is correct. Thanks everyone.
This question was called "Hot Jupiter," from Mastering Physics Ch. 12.
