.Determining Reflected & Transmitted Waves
  • Thread starter Thread starter sweetvirgogirl
    Waves
The discussion revolves around determining the reflected and transmitted waves when a beam of particles encounters a potential step. The problem involves applying continuity conditions to the wavefunction and its derivatives at the boundary of the potential step.
  • Participants explore the continuity equations that relate the incident, reflected, and transmitted waves. There is a focus on understanding the required continuity conditions and their implications for the wavefunction and its derivatives.
Some participants have provided insights into the continuity conditions necessary for the wavefunction at the barrier's edge, while others express uncertainty about the specifics of these conditions. Multiple interpretations of the continuity requirements are being discussed.
There is mention of specific values for energy and potential, as well as the form of the wavefunction, which may influence the continuity conditions being analyzed. The discussion also touches on the nature of potential barriers and their impact on wavefunctions.
sweetvirgogirl
if you know the wave ...
how do you determine the reflected and transmitted waves?
the book tells you to enforce the required continuity conditions to obtain their (possibly complex) amplitudes
You cannot expect a coherent answer when you ask something this vague.
Zz.
As vague as that question is, I think the answer you are looking for is that:
Y= Psi because I don't know how the nifty regulars use that fancy font
Yi: Incident wave
Yr: Reflected wave
Yt: Transmitted wave
Y': Derivative of wave equations with respect to position (x)
Lets assume that the potential barrier is at x = a
you have two continuity equations
Yi(a) + Yr(a) = Yt(a)
Yi'(a) + Yr'(a) = Yt'(a)
I doubt that answers your question since I am not sure what it is, but you can figure everything out from these continuity equations.
Yi: Incident wave
Yr: Reflected wave
Let me type the exact q ...
A beam of particles of energy E and incident upon a potential step of U0 = 3/4 E is described bby the wae funciton
Y(x) = 1 e^(ikx)
The amplitude of the wave (related to the number incident per unit distance) is arbitrarily chosen as unity.
a) Determine completely the reflected and transmitted waves by enforcing the required continuity conditions to obtain their (possibly comlex) amplitudes
b) Verify that the ratio of reflected probability desnity to the incident probability desnity agrees with
the equation ... T = ... R = ...
what i don't get is what the hell is "required continuity conditions"
The wavefunction and it's derivative must be continuous at the barrier's edge.
...which is a specific part of the requirement that the wavefunction be continuously derivable EVERYWHERE.
You can use https://www.physicsforums.com/misc/howtolatex.pdf" from where you can copy and paste individual characters.
wave function derivatives
Gokul, with step functions, delta-functions, and linear-cusp functions being commonplace portions of model potentials, that was a VERY misleading thing to say.
If the Potential is smooth, then the wave function will be also;
If the Potential has infinities, jumps, or kinks, then the wave function
will have discontinuous 1st, 2nd, or 3rd derivitives ...
otherwise the equation isn't satisfied.
  • · Replies 16 ·
