Determining the Density of a sphere.
  • Thread starter Thread starter teamsoulglo
    Density Sphere
6 replies · 122K views · last reply
teamsoulglo
The radius of a sphere is measured to be (6.90 0.25 ) cm, and its mass is measured to be (1.75 0.05) kg. The sphere is solid. Determine its density in kilograms per cubic meter and the uncertainty in the density. (Use the correct number of significant figures.)
Volume = (4/3) (pi)(radius)^3
= (4/3) (3.1416)(6.9/100)^3 = 1.376 X 10^-3 m^3
Density = mass / vol = 1.75 / 1.376 X 10^-3 = 1271.8 kg / m^3
= 1.27 X 10^3 kg /m^3
% error in radius = (0.25/6.9)X100 = 3.6%
therefore % error in volume = 3 X 3.6% = 10.8%
% error in mass = (0.05/1.75) X 100 = 2.86%
So % error in the density = 10.8 + 2.86 = 13.66%
Therefore undertainty in density = 13.66% of 127 X 10^3 kg/m^3
= 173 kg/m^3
So density = (1.27±0.173) X 10^3 kg/m^3
According to webassign, my answer is incorrect. I can't figure out what I did wrong. Any help would be appreciated.
My first time using this board, and no response for over 4 hours. Yet others who post after me are getting help asap. Thanks for the help guys!
Welcome to the forums teamsoulglo,
Patients is a virtue, and besides, I'd be impressed if on average questions were answered quicker on any other boards. Now, to your question, you've done everything right up until when you calculate the uncertainty in the density. Suppose we have two quantities with their appropriate errors;
[tex](A\pm\delta A)\hspace{1cm}(B\pm\delta B)[/tex]
Now, suppose we want to find X = A/B, then the uncertainty in this case is;
[tex]\frac{\delta X}{X} = \sqrt{\left(\frac{\delta A}{A}\right)^2 + \left(\frac{\delta B}{B}\right)^2}[/tex]
Also note that when you divide a value by a constant, you must also divide the error by that same constant. Hope this helps.
I was a little unclear why the radius uncertainty is multiplied my three. Is there a relation between the exponent and the amt its multiplied by?? Truly wondering.
Indeed there is (as far as I know). If we again have some quantity [itex](A\pm\delta A)[/itex] and we wish to find [itex]Z = A^n[/itex] then the error in this case is;
[tex]\frac{\delta Z}{Z} = n\cdot\frac{\delta A}{A}[/tex]
Thanks hoot. Learn something every day on this forum.
denverdoc said:
Thanks hoot.
No problem :smile:
Oh how true that is, more often that not its me doing the learning!
