High School Who Applies the Larger Force on Earth and Moon?
Fred applies a larger force when lifting a 2.0 kg rock due to Earth's stronger gravity compared to the Moon's. However, when throwing the rock horizontally at 6.0 meters per second, the force required is not solely dependent on gravity; both Fred and Jane exert the same horizontal force if the time taken to throw is equal. The vertical force needed to counteract gravity must also be considered, which is greater on Earth. The discussion highlights that while lifting requires different forces due to gravity, horizontal acceleration can be achieved with the same force regardless of location. Overall, the context of the questions leads to different considerations for force application.
Amelina Yoo
Q: Fred is on Earth, and Jane is on the Moon.
a) Each lifts a 2.0 kg rock. Who has to apply the larger force?
b) Each throws the rock horizontally with initial speed of 6.0 metres per second. Who applies the larger force?
For both questions, I wrote: Fred, because the gravity on Earth is greater than that of the Moon, and so there is a larger force acting upon the rock. But, seeing as it is my answer to BOTH question, I am feeling doubtful, because how can there be the same answer to two questions?
I believe you're right, it's Fred.
If atmospheric resistance is to be taken into account, I believe it should be Fred. If not, I think both will apply equal force. The rock will take longer to land on moon.
The second question does not have a good answer, as it is asked.
Even without leaving our planet you can achieve the 6 m/s speed of the rock with any force. It just depends on how long it takes to accelerate the rock.
Of course, besides the horizontal force, you need to apply a vertical force equal to the weight of the rock, in every case.
So assuming that both use the same horizontal force, for the same amount of time, the total force will be larger on Earth.
Regarding your concern, there is no rule to rule out same answer to two different questions.
To throw a rock requires applying force over a distance, or work, on the rock. Work is the dot product of force and displacement. There is no extra force due to gravity horizontally therefore the dot product does not vary with gravity. Therefore, both use the same force (assuming it takes the same amount of time to throw).
Lifting a rock in lower gravity requires less force. Accelerating a given mass in a direction perpendicular to any gravitational field requires the same force.
If you want to have horizontal velocity at the end of acceleration you need to exert a vertical force as well. Otherwise the rock falls during the acceleration period and the final velocity won't be horizontal. The question in the OP does not specify that is about the horizontal component of the force only.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 33 ·
  • · Replies 32 ·
9K
  • · Replies 19 ·
