Determining the molality of a solution
  • Thread starter Thread starter georgiabrown
    Molality
7 replies · 5K views
georgiabrown
In a lab, 40.3 mL Mn2+ is mixed with 5 mL H3PO4. 0.4g of potassium periodate is added. The flask is heated and then diluted to 100mL. The final solution prepared is a permanganate solution. Calculate the final molarity of the solution.
C Mn2+ = 0.06061 M (60.61 micrograms/ mL)
C H3PO4 = 15 M
V Mn2+ = 40.3 mL
V H3PO4 = 5 mL
M (Mn2+) = 54.94 g/mol
V final = 100mL
C1V1=C2V2
2Mn2+ + 5IO4- + 3H2O ---> 2MnO4- + 5IO3- + 6H+
(60.62 * 40.3 *10^-6) / (54.94 *0.100) = 4.45 *10^-4 M
The 10^-6 was used as a conversion factor from micrograms to grams.
I'm not sure if this is right, as it is not taking into account the H3PO4 added.
Sorry! The question is to find the final molarity of the solution.
Molarity of permanganate?
How many moles of permanganate created per mole of manganese?
Are you sure about it? M usually stands just for mol/L.
Yes, the molarity of permanganate. The concentration on Mn2+ was initially given in ppm (micrograms/mL) and i converted that value to mol/L...
If you have converted 60.61 ppm to 0.06061 M you did it wrong.
You have not answered my question.
How many moles of manganese initially?
What is the final volume?
What is concentration definition?
methods
I think i corrected my conversion : 60.61 ug/mL = 1.10 * 10^-3 M
1. n = cv
= 4.43 *10^-5
2. 1:1 mole ratio
3. final volume = 0.1 L
4. concentration = 4.43*10^-4
is the H3PO4 not involved in the reaction?
I got 4.45x10-4M, that's most likely because of some rounding errors and/ordifferent molar masses used - but in general that's the same.
Phosphoric acid... This is a limiting reagent problem. Think about amounts of substances used.
