Determining the possible time interval between two sine waves
The discussion revolves around determining the minimum time interval between two identical sinusoidal waves with a given wavelength and speed. The phase difference of the waves is calculated to be 2/3 pi, leading to the use of the equation T/3 = 1/3f to find the time interval. Clarification is sought on the significance of the number 3 in the equation, which relates to the phase difference in terms of cycles. The conversation emphasizes understanding how phase shifts correlate with time intervals and periods of the waves. Ultimately, the relationship between phase shifts and time intervals is crucial for solving the problem accurately.
randoreds
ok I just got stuck half way into a problem, I would like it if someone explained it!
Ok the question says, two identical sinusodial waves with a wavelength of 3.0 m and traveling in the same direction with a v of 2m/s. Starting from the same point, just the second waves starts later. and the amplitude of the resultant wave is the same as each of the initial waves.
Find the min. time interval between the two waves
So, I would suppose I would need the phase difference, so I found it and it is 2/3 pi. now I asked my teacher and he said to use this equation to find the time interval.
T/3 = 1/3f
so I get I would just sub for f with v and wavelength
what I don't get is the 3. I see it comes from my phase difference, but could someone explain that a little further. Like what if my phase shift was 4/5 pi? would the equation become T/5 =1/5f ?
because I don't really get where the two goes and how I would know to put a 3 under T
I see emptiness...
rollingstein said:
I see emptiness...
Fixed it!
T/3 = 1/3f
That (2/3)[/size] being radians?
You know that 1 cycle corresponds to 2[/size] radians.
So then x cycles correspond to (2/3)[/size]. Find x.
randoreds said:
T/3 = 1/3f
Yes, period = 1/frequency, and you can calculate the frequency from wavelength and speed. What remains is to say what one whole period corresponds to in terms of phase, and what fraction of that is the phase shift you found.
T
Thanks, I think I get it. just to be sure. Theoretically if I found the phase shift to be 3/5 pi and all the other variable were the same as in the problem. My T would be 2/5 T because one sine wave is 2/5 pi ahead of the other, right?
No. Try answering my question first: what, in radians, would a phase shift of a whole period be? Then, what fraction of that would 3/5 pi be?
  • · Replies 30 ·
