Determining the uncertainty of the coefficient of friction
The discussion focuses on calculating the uncertainty of the coefficient of friction (myoo) using experimental data for friction force and normal force. The user initially calculated maximum and minimum values for myoo by adjusting the forces with their respective uncertainties of +/- 0.1. However, discrepancies arose when applying the same method to different data sets, leading to confusion. The correct approach involves propagating uncertainties using the formula for independent variables and considering the mean and standard deviation of the myoo values for a more accurate overall uncertainty assessment.
  • Understanding of basic physics concepts, specifically friction and normal force.
  • Familiarity with the coefficient of friction (myoo) and its calculation.
  • Knowledge of uncertainty propagation in measurements.
  • Ability to perform statistical analysis, including mean and standard deviation calculations.
  • Learn about uncertainty propagation techniques in physics experiments.
  • Study how to calculate the slope of a graph and its uncertainty for linear regression.
  • Explore statistical methods for analyzing sets of experimental data, including mean and standard deviation.
  • Investigate the use of software tools for data analysis and graphing, such as Python's NumPy and Matplotlib.
Students in physics courses, laboratory technicians, and anyone involved in experimental physics who needs to understand and calculate uncertainties in measurements.
Nick tringali
So far i know that the uncertainty of the force of friction is +/- 0.1 and the uncertainty of the force normal is +/- 0.1 also.
Force of friction=(myoo)(force normal)
Myoo= force friction / force normal
My data is
Force of friction | myoo | fnormal
0.0 | 0.0 | 0.0
1.4 | 0.264 | 5.3
1.9 | 0.260 | 7.3
3.2 | 0.262 | 12.2
4.1 | 0.272 | 15.1
4.6 | 0.269 | 17.1
Thats my calculated data so first I added 0.1 to1.4 and got 1.5 then I added 0.1 to 5.3 and got 5.4 then divided 1.5/5.4 and got 0.27777 (which is my max myoo value) now to get the min value I subtracted 0.1 from 1.4 and 5.3 and divided again 1.3/5.2 and got .25 for the min myoo value then i subtracter 0.27777 from 0.25 and got my uncertainty to be 0.0277, the problem is i tryed the same prossess with another set of values from my data table and got a different uncertainty. For the last set of numbers with frictonal force of 4.6 i got the uncerntanty to be 0.00855 (i did the same process as before) All of my class mates are doing different ways.
This does not make sense to me ...
You need to be clear about what is being attempted ... myoo is the coefficient of friction I take it?
I cannot tell what you have done -
Let f = ffriction is the friction force, N = fnormal is the normal force, and mu or ##\mu## is myoo is the coefficient of friction. (saves typing)
You would normally want to measure f and N to calculate mu.
You say you have calculated all three for the table ... your problem statement gives uncertainties for f and N, which suggests a measurement for f and N.
OK: assuming you have friction ##f\pm\sigma_f## and normal force ##N\pm\sigma_N## then ##\mu = f/N## - f and N are independent and divided so you propagate the relative errors (percentage errors).
The rule is as for ##z=xy##, i.e. $$\left(\frac{\sigma_z}{z}\right)^2=\left(\frac{\sigma_x}{x}\right)^2+\left(\frac{\sigma_y}{y}\right)^2 $$
... this you'd do for every line, giving you the uncertainty for each value of mu.
Better: plot a graph of f vs N - the slope will be mu, and you can calculate the uncertainty of the slope.
Also better - find the mean and standard deviation of the mu column of your table ... the value of mu is ##\mu = \mu_{ave} \pm \sigma /\sqrt{n}## where n is the number of entries in the columb.
Note: your table mu value for f=0 is wrong. But I don't know what you actually did: I'm just guessing.
It may help you to see:
https://www.physicsforums.com/threads/uncertainty-of-an-average.612633/
Thanks simon, but what do those symbols in the numerator represent?
That is uncertainty right?
Would each value of myoo have there own different uncertainty then, I was looking for the uncertainty for the myoo column as a whole, sorry if I am not following you 100%. Should i just use that formula you gave?
I also have a graph like that and the slope too of the line of best fit.
You can edit your posts if you want to add something. I merged your posts.
The symbols in the numerators are the uncertainties, right.
Correct. You can calculate an overall uncertainty out of those different values later.
Yes. Or use the fit approach.
Unrelated:
A (positive) fraction gets maximal if the numerator is maximal and the denominator is minimal. 1.5/5.2 is larger than 1.5/5.4. But that approach is not right anyway.
