Determinism and causality in QM - a case
54 replies · 5K views
entropy1
I hope my thread won't be closed (too soon) and some forummers can shed their light over my question.
Let's suppose a deterministic universe. I assume all events have a cause, that everything is cause and effect. Then, given that the state of the universe at some instant is X, and this leads to event A, then, if instead event A did not happen, the state of the universe could not have been X, right?
But if we consider the MWI, then X can happen at t0, and then the universe can split in for instance branch L1 and branch L2, with A happening in L1 and not in L2, both being preceded by X. This seems to disagree with the previous case.
So how should we view this case?
In other words, let's assume a universe that is not governed by quantum mechanics.
As far as we know, we don't live in such a universe so speculating about how one might behave is not going to be especially helpful, and any attempt to reconcile it with quantum mechanics will be inherently inconsistent.
[When posting in the main QM forum I often feel the need to apologize to the Bohmians. This is one of those times]
No. You explicitly give a counterexample in your follow-up question.
No, it doesn't, because you have not carefully thought through what the "state of the universe" is in your two cases.
In your first case, you were implicitly assuming a classical universe in which the state of the universe, the thing that evolves deterministically, is identical with "what happens".
But in your second case, you were assuming the MWI, in which the state of the universe is not identical with "what happens". The state of the universe in the MWI, the thing that evolves deterministically, is a quantum state, which contains amplitudes for various different, mutually exclusive happenings. (Even this view requires choosing a basis, and different choices of basis can lead to different, mutually contradictory descriptions of the state in terms of the possible "happenings" it contains amplitudes for.)
So the logic you were using in your first case to deduce "if A does not happen, X could not have happened" from "if X happens, A will happen" simply doesn't apply to your second case.
Actually, the "cause and effect" assumption is irrelevant to the OP's scenario, and could simply be omitted.
However, I don't agree that "everything is cause and effect" is inconsistent with QM. I think it depends on which interpretation you adopt and what viewpoint you take on what "cause and effect" actually mean.
It is true that "cause and effect" don't appear anywhere in the basic rules of QM, as described for example in our Insights article on the subject, but the same is true in classical physics; "cause and effect" aren't anywhere in the basic rules there either. So I don't think one can say a particular scenario is inconsistent with either classical or quantum physics based on any assumptions about "cause and effect".
Very clear. Thank you.
It seems to me that if it were true, we would have had determinism, following your deduction. So does that mean we don't have determinism, like @Nugatory says?
It's the assumption of determinism that I'm objecting to - aside from the pro forma apology to the Bohmians I don't see how to eliminate nondeterminism from standard QM.
The OP assumed the MWI (and I realized that that means this thread belongs in the interpretations forum, so I have just moved it there). The MWI is deterministic; it's just that you have to be clear about what the "state" that evolves deterministically is. From the standpoint of the MWI, the "nondeterminism" in standard QM is only an appearance, just as the occurrence of a single outcome from a measurement is only an appearance.
(The Bohmian interpretation, as you note, is also deterministic, but in that interpretation, the "state" is basically the same as in classical physics, and can be equated with "what happens" in the OP's logic.)
PeterDonis said:
No. The MWI is deterministic. See my response to @Nugatory just now.
The wavefunction may be deterministic, but if you adopt that, you have to accept that ALL possible measured outcomes are realized. Subjectively that is not the case; you then have a single probable outcome.
Which is exactly what the MWI says, and you said you were assuming the MWI for this discussion.
And according to the MWI, that subjective appearance is only an appearance. You're the one that picked the MWI for this thread; that means you need to use it.
I think you deduction holds, but as I said, I think it suggests my second case, in which I adopt MWI for sake of reason, is not deterministic as a consequence of your reply. And that has to do, in my view, with the difference between the objective and subjective approach in this matter. We have the wavefunction on one side, and measurement outcomes on the other side. Objectively, we have determinism of the wavefunction.
entropy1 said:
I think it suggests my second case, in which I adopt MWI for sake of reason, is not deterministic as a consequence.
No, it doesn't. It means you are refusing to actually adopt the MWI and use what it actually says.
Determinism is never subjective, so it makes no sense to use a subjective approach to address a question about determinism.
In the MWI, yes. Which means the MWI, as I have said, is deterministic, since, as above, the objective approach is the only one that makes sense when addressing a question about determinism.
MWI does have an objective and a subjective aspect. It says about the subjective aspect that only a single outcome is observed by the observer.
Wait, I think we are in fact agreeing that in the second part of the case "if A does not happen, X could not have happened" does not hold. That is in fact what I am saying there.
"If X happens, A will happen" is determinism to me. So if it doesn't apply, either the wavefunction or the measurement outcomes are not deterministic, and it must be the latter I think.
It all is so ingenious :oldbiggrin:
No, that's not what the MWI says. The MWI says that the concept of "observer" that you are implicitly using is invalid.
Here is a correct description of what happens to an "observer" when a measurement is made, according to the MWI:
Before measurement: "O-before" has not observed any result, and "S" (the system to be measured) is in some prepared state.
After measurement: The joint system is in an entangled state which is a combination of "O-after-observed-outcome-1" ##\otimes## "S-1" (the "outcome 1" state of the system S) and "O-after-observed-outcome-2" ##\otimes## "S-2" (the "outcome 2" state of the system S).
Now, what does the term "observer" refer to in the above?
If it refers to "O-before", then that observer has not observed any outcome.
If it refers to either "O-after-observed-outcome-1" or "O-after-observed-outcome-2", then each of these "observers" has observed a single outcome, but neither one is "the" observer, and neither one is "the same observer" as "O-before". There simply is not any "observer" with a single continuous identity before and after measurement in this sense.
If it refers to the subsystem (set of degrees of freedom) to which the "O" states refer, then that subsystem does not have a definite state after the measurement and so has not observed any definite outcome.
No. I am saying that that statement is not even well-defined if we adopt the MWI, because the underlying notion of "happening" that the statement is using is not well-defined if we adopt the MWI. A statement can't be either true or false if it isn't well-defined to begin with.
There is an alternative, but it doesn't help you any. See below.
And this is true in the MWI, for the correct concept of "happening" in the MWI. In the MWI, what "happens" in terms of determinism is the wave function. And the wave function obeys both of your statements: if the wave function is X, it will be A, and if it is not A, it could not have been X. So the MWI is deterministic by your definition, if we use this notion of "happening".
However, you are refusing to use the correct notion of "happening" for the MWI, and trying to apply a different notion of "happening" that is well-defined in your other case (classical physics), but is not well-defined if we adopt the MWI. And in that case, my first comment at the start of this post applies.
Either way, no, we do not agree.
We were talking past each other: you was referencing exclusively to the wavefunction and I wasn't making the distinction, which I should have.
I thought I had posted a reply concerning this, but apparently not in this thread. My view is that MWI is deterministic considering the wavefunction, but the measurement outcomes, in my view, are not necessarily.
I guess it depends on the way you look at it. I feel there has to be a sort of objective/subjective distinction, that is, the wavefunction (objective) and the measured outcomes (subjective), and those related.
We might, though. I understand what you are trying to say to me.
That's because, in the MWI, the wave function is all that there is. There is nothing else. So the only thing you can reference if you're talking about the MWI is the wave function.
Yes, the measurement outcomes are deterministic in the MWI. The MWI says that all possible outcomes occur, every time, as a deterministic fact. The outcomes are all part of the wave function after measurement, which, as I have said and you have agreed, evolves deterministically in the MWI.
No, the measurement outcome is not subjective in the MWI. The measurement outcome is an objective fact about each branch of the entangled wave function of the total system after measurement.
I'm not sure you did. See above.
@PeterDonis , I understand exactly what you are saying. I feel we have a difference of conception. Of course you can claim that MWI is deterministic, because it is. But the measurement outcomes we observe are not ALL measurement outcomes at once. We observe a single outcome with the probability given by the Born rule.
I continue to doubt that you actually do, since you keep making statements that are simply wrong if the MWI is assumed. See below.
I agree in the sense that I have a correct conception of what the MWI actually says, and you have an incorrect one. See below.
Not in the MWI. In the MWI, there is no single "we" after the measurement in the sense you are using the term. There are multiple copies of "we" after the measurement, one in each branch, and each copy of "we" observes a different outcome. So any statement that assumes there is only a single "we", as yours does, is simply wrong if the MWI is assumed.
Also, since all outcomes occur in the MWI, it is meaningless to talk about the "probability" of a particular outcome. In fact, a consistent explanation for the Born Rule in the MWI is one of the primary outstanding issues with that interpretation. So if you want to say you question whether the MWI is correct because it can't account for the Born Rule, that's fine. But that's not what you are saying; what you are saying is simply a wrong description of what the MWI says.
I disagree because subjectively we experience something different than objectively. I, in this branch, don't experience other branches. They withdraw from my experience in this branch. If you are fine with the notion that other branches ARE experienced, that is where I don't even disagree, it is just that my way of viewing is one too.
Although that is a serious issue, I'm not claiming that.
In short: I don't disagree with you that MWI is deterministic, but I would rather include the distinction between objective and subjective. I think we disagree there. But I have to say you make a strong case of course. I will study it further.
While this is true, it doesn't change what I said. Remember we are assuming here that the MWI is true. That means we have to adopt the MWI's viewpoint, not yours. And in the MWI's viewpoint, this...
...is not just a "notion" or "another way of viewing it", it is a fact. It is not open to subjective interpretation. It is not a "viewpoint" that you can choose whether or not to take. It is reality. That is what the MWI says.
entropy1 said:
it is just that my way of viewing it is one too.
Not if the MWI is assumed to be true. See above.
The way you are doing it, you can't, if the MWI is assumed to be true. See above.
I am not claiming anything and not even disagreeing, I am stating an axiom.
"Other branches are experienced" is an axiom if we assume the MWI is true, yes.
But "my way of viewing it is one too" is not an axiom if we assume the MWI is true.
entropy1 said:
So tell me, @PeterDonis , is your experience objective or subjective?
Before I can even answer this, since we are assuming the MWI is true, you need to give me definitions of "objective" and "subjective" that are well-defined if the MWI is true.
This may be not so "well-defined", but I think that probably in the different "worldthreads", we observe different measurement outcomes, so that the experience of all subsequent outcomes differ in each thread, a thread being a macro-outcome paired with a micro-outcome? Although I am not so sure that all subsequent outcomes in each thread should differ that much from those in another thread.
But what do I know? Have I mentioned that? No point in doing this, right?
As to your last statement here, that will depend on the measurements being made.
How does any of this relate to "objective" or "subjective"?
