Calculate Sin(A+B) with CosA= 1/3 and SinB=1/4: Check My Work
  • Thread starter Thread starter majinknight
The discussion focuses on calculating sin(A+B) given CosA=1/3 and SinB=1/4. The correct formula used is Sin(A+B) = SinACosB + CosASinB, leading to the expression Sin(A+B) = (√8/3)(√15/4) + 1/12. The final answer is correctly simplified to (√120 + 1)/12, although there was confusion regarding the notation and parentheses used in the final expression. The importance of proper notation in mathematical expressions is emphasized.
  • Understanding of trigonometric identities, specifically the sine addition formula.
  • Familiarity with the Pythagorean theorem for calculating triangle sides.
  • Knowledge of square roots and their simplification.
  • Basic algebraic manipulation, including handling fractions and parentheses.
  • Study the sine addition formula in trigonometry.
  • Practice solving problems involving the Pythagorean theorem.
  • Learn about proper mathematical notation and parentheses usage.
  • Explore the properties of trigonometric functions in different quadrants.
Students studying trigonometry, educators teaching mathematical notation, and anyone looking to improve their problem-solving skills in trigonometric calculations.
majinknight
Ok So i finished my questions and was wondering if someone could check my work to see if i did it right.
Question: If CosA= 1/3, with 0<A<pie/2, and SinB=1/4, with pie/2<B<pie, Calculate sin(A+B)
My Solution:
Sin(A+B)= SinACosB + CosASinB
=SinACosB + (1/3)(1/4)
SinACosB + 1/12
Ok Now i drew Triangle A and labeled the bottom 1 and hypotaneous 3. Then used the theorum to get the last side is square root 8.
I made Triangle B and labelled hypotaneous 4, adjacent side being 1 and used theorum to get the opposite side to be square root of 15.
=(square root8/3)(square root15/4) +1/12
=(square root120/12) + 1/12
to get my final answer of squareroot 120 +1 /12.
Is that correct?
Ouch! Your trigonometry is excellent- your notation is horrible!
You are exactly right (and for the right reasons!) that
sin(A+B)= =(&radic;(8)/3)(&radic;(15)/4) +1/12
but then you seem to have lost control of your parentheses.
sin(A+ B)= &radic(120)/12+ 1/12
= (&radic(120)+ 1)/12
which is not the same as &radic(120)+ 1/12 which is how I would have interpreted "squareroot 120 +1 /12".
It's not your use of "squareroot" instead of &radic; I am complaining about- it's your use of parentheses.
(squareroot(120)+ 1)/12 would be a correct answer.
shouldn't cosB be negative for \frac{\pi}{2}&lt;B&lt; \pi
