Did I do this (complex) integration correctly?
The discussion revolves around evaluating the integral \(\int_C \frac{1}{z^2 + 4} dz\) where \(C\) is the unit circle. Participants explore the implications of the integral's setup, particularly regarding the path of integration and the properties of the function involved.
  • Participants discuss various methods of integration, including parameterizing the unit circle and considering the function's analyticity. Some question the validity of their approaches and the assumptions made about the integral's evaluation.
There is an ongoing exploration of different methods to evaluate the integral, including references to Cauchy's Theorem and the properties of holomorphic functions. Some participants express uncertainty about their previous attempts and seek clarification on the correct approach.
Participants note that the function \(\frac{1}{z^2 + 4}\) is analytic inside the unit circle, which raises questions about the necessity of finding an antiderivative. There is also mention of potential confusion stemming from the use of outdated terminology in the textbook.
moxy
Given C is the unit circle, evaluate [tex]\int_C \frac{1}{z^2 + 4} dz[/tex]
unit circle: [itex]z = e^{iθ}[/itex]
The problem doesn't specify how many times to go around the unit circle or which way, so I'm going to assume once and counterclockwise.
[tex]z = e^{iθ} \ \ , \ θ \in [0, 2\pi][/tex]
[tex]dz = ie^{iθ}dθ[/tex]
[tex]\int_C \frac{1}{z^2 + 4} dz = \int_0^{2\pi} \frac{1}{(e^{iθ})^2 + 4} ie^{iθ}dθ[/tex]
[tex]= \frac{1}{2} \arctan{\left(\frac{e^{iθ}}{2}\right)} \Big|_0^{2\pi}[/tex]
[tex]= \frac{1}{2} \arctan{\left(\frac{e^{0i}}{2}\right)} - \frac{1}{2} \arctan{\left(\frac{e^{2\pi i}}{2}\right)}[/tex]
[tex]= \frac{1}{2} \arctan{\left(\frac{1}{2}\right)} - \frac{1}{2} \arctan{\left(\frac{1}{2}\right)} = 0[/tex]
I'm pretty confident about it, but I'm always wary of numerical problems that turn out so nicely. Is this correct, or did I royally screw it up?
Suppose the problem were integrate 1/z around the unit circle. The antiderivative is log(z). So the result must be log(e^(2*pi*i)-log(e^(0))=log(1)-log(1)=0. Would you believe me? You shouldn't. Because it's wrong. That's what you are doing. In this case you got the right answer. But the method is unsound. There's a much easier way of evaluating that integral with less risk. Any idea what it might be?
Wait, if the problem was f(z) = 1/z, then I'd do the same as I did above and get,
[tex]\int_c \frac{1}{z} dz= \int_0^{2\pi} \frac{1}{e^{iθ}} ie^{iθ} dθ = \int_0^{2\pi}i dθ= i \int_0^{2\pi}dθ = (i) θ\bigg|_0^{2 \pi} = i(2\pi - 0) = 2\pi i[/tex]
Should I be doing some substitutions, or finding the inverse and using inverse function integration?
[tex]\int_c \frac{1}{z} = \int_0^{2\pi} \frac{1}{e^{iθ}} ie^{iθ} dθ = \int_0^{2\pi}i dθ= i \int_0^{2\pi}dθ = (i) θ\bigg|_0^{2 \pi} = i(2\pi - 0) = 2\pi i[/tex]
You did that correctly by reducing the integral to a real integral where you can safely use the antiderivative. So you'll agree using log(e^(2*pi*i))-log(1) is wrong for 1/z? That was my point. I'm not sure where you are in complex variables, but 1/(z^2+4) is analytic inside the unit circle. It doesn't have any poles or singularities there. Does that suggest anything? You don't even need an antiderivative.
Can I just use Cauchy's Theorem to say that since C is simple, closed, and rectifiable and f(z) is holomorphic in and on C the [itex]\int_c f(z) dz = 0[/itex]?
The book we use is very old and uses a lot of out of date terms...
That's exactly what you should say. The poles are at +/-2*i. They are outside of the unit circle. No need for an arctan or anything. Nor any need to say which way around the unit circle or how many times. It's still zero.
Okay, that makes enough sense. Though I have a few other integration problems, namely ones from a section in the book before Cauchy's thm is mentioned. I guess if I did it incorrectly above, then I did all of the other ones wrong. Is there a method to actually calculate the integral?
There's always what did you did the 1/z problem. Just saying log(e^(2*pi*i))-log(1)=0 is wrong suggests just saying arctan(e^(2*pi*i))-arctan(1)=0 might also be wrong. Try and reduce the problem to real integrals where you know what you are doing. The problem with the log thing is that log in complex variables is multivalued. arctan probably is as well.
Let θ = ∏t => dθ = ∏dt
[tex]\int_0^{2\pi} \frac{1}{(e^{iθ})^2 + 4} ie^{iθ}dθ = \frac{1}{\pi}\int_0^{2} \frac{1}{(e^{i\pi t})^2 + 4} ie^{i\pi t}dt[/tex]
[tex]= \frac{i}{\pi}\int_0^{2} \frac{1}{1 + 4} e^{i\pi t}dt = \frac{i}{5\pi}\int_0^{2} e^{i\pi t}dt = \frac{i}{5\pi}\int_0^{2} [cos{(\pi t)} + isin{(\pi t)}]dt \ , \ \ etc.[/tex]
Is this valid? Though I could stop with the second to last part and integrate e^(∏ti) as in the real case.
No, replacing exp(2*pi*i*t) by 1 doesn't work. It's not the same as exp(2*pi*i)^t. Actually, I've got another suggestion if you don't want to use Cauchy's theorem. Use partial fractions to write 1/(z^2+4)=A/(z+2i)+B/(z-2i). Find A and B and then integrate.
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 105 ·
13K
