Difference between 2 equations in percentage
  • Thread starter Thread starter FrostScYthe
    Difference
3 replies · 6K views · last reply
FrostScYthe
This is probably a dumb question, but I was asked to get a measurement in percentage between 2 linear equations with different slopes.
I have the following linear equations
y1 = 450463x + 50000
y2 = 668453x + 100000
Can I determine a constant difference between them, in terms of A is X percent greater than B? if so, how do I calculate it?
my guess is :
668453 - 450463
----------------- = 32.6 %
668453
However when I test points it doesn't work, it varies, hmm maybe I'm looking for the wrong percentage? Any ideas?
This is a question not a tutorial. I am moving it to the "precalculus homework" section.
No, you can't. The percentage difference between y1 and y2 is itself a function of x, not a constant.
my guess is :
668453 - 450463
668453
I think "a constant difference" is not exactly what you want! You need something that relates y2 with y1, correct? If so, you may obtain a linear relation between y1 and y2 (divide each equation by its slope, then subtract the two equations) you should obtain a linear equation y2 = m * y1 + b
surely the equation describe the relation between y1 and y2. But you may do something extra
Can you tell on what conditions one may say y2 is P% of y1? what P equals to?
This however, is not the same as percentage difference, as HallsofIvy mentioned, the percentage difference varies according to x so it can't be constant.
