Difference between accelerometer and vibration sensor
Accelerometers and vibration sensors are closely related, with vibration sensors often utilizing accelerometers for their functionality. The primary distinction lies in their firmware and signal processing; accelerometers focus on detecting acceleration, while vibration sensors are designed to analyze vibrations specifically. Older vibration sensors measured position or velocity, whereas modern sensors typically employ MEMS accelerometers to capture high-rate acceleration data. These devices use digital signal processing to filter out irrelevant noise, focusing on the frequencies pertinent to vibration detection. Understanding these differences is crucial for selecting the appropriate sensor for applications like monitoring pump vibrations.
rama1001
I have searched on web but i did not get exact explanation on about these topics. Could someone clear me. I am looking for accelemeter to my pump that can get the information about vibrations.
There's not a real difference, but a vibration sensor is one application for an accelerometer. Have a look around for some vibration analysis equipment providers.
Still, i am in confustion and can not able to figure out the difference. Can some one point out the difference here?
Does accelerometer detect the vibrations?
The difference is in the firmware.
Older vibration sensors sensed position or velocity. Newer ones tend to use a MEMS accelerometer to detect vibrations. Accelerometer-based vibration sensors often capture acceleration data at a high rate. The built-in DSP uses a band pass filter to eliminate the very high frequency noise and to eliminate the low frequency accelerations that are of little interest when it comes to detecting vibrations.
A MEMS accelerometer that is used as an accelerometer will use different signal processing compared to a MEMS accelerometer that is targeted to detect vibrations. Here it is the low frequency accelerations that are of primary interest. When it comes to detecting acceleration, the vibrations are just noise that are best eliminated at the source.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 16 ·
  • · Replies 0 ·
24K
