Difference between (log₈(x))² and log₈(x)²
  • Level: High School
  • Thread starter Thread starter chemistry1
    Logarithm
24 replies · 5K views
chemistry1
Hi, quick question.
Is there a difference in notation when I say :
(log8(x))^2
and
log8(x)^2
Is it different or the same ? Thank you !
Mathematics news on Phys.org
I would say they mean the same thing. log8(x^2) would be different. To me, at least, log8(x)^2 means squaring log8(x). Hope that helps!
Well, I thought that saying log8(x)*log8(x) would be different than log8(x)^2
Ill keep waiting
Thank you
chemistry1 said:
Hi, quick question.
(log8(x))^2
and
log8(x)^2
The first one is clear, but the second one is ambiguous. It could be interpreted as either (log8(x))2, or as log8(x2).
Parentheses should be used to make your meaning clear.
But with the first one could I say something like : 2*(log8(x)) ? ty
I don't see why not. What's in brackets is considered a single entity.
(log8(x))2 ≠ 2*log8(x) ! That's not how the log properties work.
loga(x2) = 2 loga(x). This isn't what you have in the first example.
See above.
Of course. :-p
As Mark44 said, just use parentheses to make things unambiguous.
- [itex](\log_8 x)^2[/itex] means one thing.
- [itex]\log_8 (x^2)[/itex] means another thing (which happens to be the same thing that [itex]2\log_8 x[/itex] means).
- Nobody is stopping you from writing [itex]\log_8(x)^2[/itex], but I wouldn't write it, because it's not crystal clear what it means.
Ok, but what is the meaning of : (log8(x))^2
is it (log8(x))(log8(x)) ?
Yes, this is clear.
And how would you simplify it ??
log8 x^log8(x)
Is this valid ?
log8 x^log8(x)
Is this valid ?
To me, this is the same as log8 (x^log8(x)), because you can only have a single input with the function log8.
Look, here's the reason why I'm asking the question :
(log8(x))^2+2(log(x))+1=0
I'm not able of finding a way to solve this. The closest answer I got was 1/64. Can somebody help me ?
Yes.
log8 x^log8(x)
Is this valid ?
Not if you mean (log8(x))2
Did you omit the base in the second term? Should it be log8(x)?
If so, your equation is quadratic in form. If you let u = log8(x), then the equation can be written as x2 + 2x + 1 = 0, which can be factored.
Mark44 said:
Yes.
Ahh... WEll... Thank you !
AH yes, I forgot it ! What do you mean by u= ... ?
Just replace log8](x) by u in your equation. The you have a true quadratic, not one that is just quadratic in form.
Solve the equation u2 + 2u + 1 = 0 for u, and then solve for x by undoing the substitution.
u^2+2u+1=0
(u+1)(u+1)=0 SOlution : u=-1
After I am not sure of understanding what you mean... Sorry xD
chemistry1 said:
u^2+2u+1=0
Since u = log8x, you have -1 = log8x.
chemistry1, keep in mind that a logarithm is an exponent on a particular base. For your equation, log8(x) is -1. This means that -1 is the exponent on the base (8) that produces x.
