Different metrics same topology?
  • Thread starter Thread starter 5kold
    Topology
5kold
different metrics... same topology?
Let (X,d) be a metric space. Define d':X x X-->[0,infinity) by
... d(x,y) if d(x,y)=<1
d'(x,y)=
... 1 if d(x,y)>=1
Prove that d' is a metric a d that d a d d' define the same topology on X.
This is a weird seeming metric. I am not sure how they describe the same thing except I have one example that kind of makes sense.
Imagine an infinite cylinder radius 1/2 "endowed" with metric d. Then imagine an eye observing it from directly above. To the eye, it sees no depth to the cylinder, so it can at best describe the cylinder with metric d'.
Now let x be on the very edge of the top of the cylinder and y be some ways down the side of the cylinder directly across from x. It doesn't matter to the eye.. for all it can see, x and y are just 1 unit apart since they are on opposite sides of the cylinder.
Maybe this doesn't make sense. But how would I show that d' is a metric? And what about them describing the same topology? Please help? Thanks!
You prove that d' is a metric by proving it satisfies the axioms of being a metric, assuming that d is indeed a metric.
To show they induce the same topology you must consider the topology that one or the other induces. What is a basis for each topology?
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
