Different Substitution for Solving an Integral
The forum discussion centers on solving the integral ##\int \frac{1}{x\sqrt{3x^2+2x-1}}dx## using different substitution methods. The user initially employed the substitution ##\frac{1}{u}## and later attempted a more complex substitution involving ##t##, leading to confusion about the correctness of their approach. Ultimately, both methods yield equivalent results differing only by a constant, as confirmed by Mathematica. The discussion highlights the importance of recognizing hidden constants in integrals, particularly in improper integrals.
  • Understanding of integral calculus, specifically techniques for solving integrals.
  • Familiarity with trigonometric substitutions and their applications in integration.
  • Knowledge of algebraic manipulation and completing the square.
  • Experience with computational tools like Mathematica for verifying integral results.
  • Explore advanced techniques in integral calculus, focusing on trigonometric substitutions.
  • Learn about the properties of improper integrals and how to handle constants of integration.
  • Investigate the use of computational tools like Mathematica for solving complex integrals.
  • Study the relationship between different forms of antiderivatives and their constants across disconnected domains.
Mathematics students, educators, and professionals engaged in calculus, particularly those focused on integral calculus and its applications in various fields.
12Element
TL;DR
Asking about multiple approaches for integration by substitution with an integral involving the reciprocal of a square root of a quadratic equation.
I have a question about how to solve the following integral: ##\int \frac 1 {x\sqrt{3x^2+2x-1}}dx##, I know how to get the right answer (which agrees with WolframAlpha and the book I got the question from) through substituting ##\frac 1u## for ##x##, completing the square and finally doing a trig substitution. However, I'm not sure why I'm not getting the right answer with the below approach, I would appreciate it if someone looks at my solution and tell me where and why I'm wrong.
$$ \int \frac 1 {x\sqrt{3x^2+2x-1}}dx$$
Using the below substitution:
$$3x^2+2x-1=3\left( t-x \right)^2$$
$$3x^2+2x-1=3t^2-6tx+3x^2$$
$$6tx+2x=3t^2+1$$
$$x=\frac {3t^2+1}{6t+2}$$
The derivative of ##x## with respect to ##t## is:
$$\frac {dx}{dt} = \frac {6t \left( 6t+2 \right) - 6 \left( 3t^2+1 \right)} {\left( 6t+2 \right)^2} = \frac {36t^2+12t-18t^2-6} {\left( 6t+2 \right)^2}$$
$$dx = \frac {6 \left( 3t^2+2t-1 \right)} {\left( 6t+2 \right)^2}dt$$
Also, to find the value of ##t##:
$$\sqrt {3x^2+2x-1}=\sqrt{3}\left( t-x \right)$$
$$t= \frac {\sqrt {3x^2+2x-1}}{\sqrt{3}} + x$$
To find the value of ##\sqrt {3x^2+2x-1}## in terms of ##t##:
substituting for ##x## with the value derived above:
$$\sqrt {3x^2+2x-1}=\sqrt{3}\left( t-\frac {3t^2+1}{6t+2} \right)=\sqrt{3}\left( \frac {6t^2+2t-3t^2-1}{6t+2} \right)$$
$$\sqrt {3x^2+2x-1}=\sqrt{3}~ \frac {3t^2+2t-1}{6t+2} $$
Substituting back into the original integral:
$$ \int \frac 1 {x\sqrt{3x^2+2x-1}}dx = \int \frac {\frac {6 \left( 3t^2+2t-1 \right)} {\left( 6t+2 \right)^2}}{\frac {3t^2+1}{6t+2} \sqrt{3}~ \frac {3t^2+2t-1}{6t+2}}dt= \frac6{\sqrt{3}}\int\frac1{3t^2+1}dt $$
$$= \frac2{\sqrt{3}}\int\frac1{t^2+ \frac13}dt = \frac2{\sqrt{3}}\sqrt{3} \tan^{-1} \left(\sqrt{3} t\right) + C$$
Substituting back for ##t## with ##x##:
$$= 2\tan^{-1} \left[ \sqrt{3}\left( \frac {\sqrt {3x^2+2x-1}}{\sqrt{3}} + x\right) \right] + C$$
$$= 2\tan^{-1} \left( \sqrt{3x^2+2x-1} + \sqrt{3}x \right) + C$$
For comparison, what is the right answer you got first ?
You're not wrong: both integrals are the same, they just differ by a constant!
Using Mathematica, your original indefinite integral is given by:$$I\equiv\int\frac{1}{x\sqrt{3x^{2}+2x-1}}dx=-2\tan^{-1}\left(\frac{\sqrt{3x^{2}+2x-1}}{3x-1}\right)+C\tag{1}$$whereas using your substitution it evaluates to:$$I_{S}\equiv2\tan^{-1}\left(\sqrt{3x^{2}+2x-1}+\sqrt{3}x\right)+C_{S}\tag{2}$$(Incidentally, Mathematica's change-of-variable operation agrees with your substitution and the form of the resulting integral.) Taking the difference of (1) and (2) and performing some algebra (or what's easier, just graphing the difference vs. ##x##) shows that:$$
I-I_{S}=C-C_{S}=\begin{cases}
\frac{2\pi}{3} & \left(x<\frac{1}{3}\right)\\
-\frac{4\pi}{3} & \left(x>\frac{1}{3}\right)
\end{cases}\tag{3}
The answer can be in either form ##\ -sin^{-1} \left(\frac{1-x}{2x} \right)+C= \ -2tan^{-1} \left( \frac {\sqrt{3x^2+2x-1}}{3x-1} \right)+C ##.
\end{cases}\tag{3}
Thanks a lot, this is really interesting, I only have a Casio calculator and whenever substituting random values in both solution does not give the same number I assume my solution is wrong. I only thought that hidden constants are associated with logarithmic functions, now I know they can be more devious than what I thought. Not to mention improper integrals (like in this case) where multiple constants can be present along the domain. Thanks again.
Thanks. I let wolfram draw the graphs.
https://www.wolframalpha.com/input?i=plot+y=-+arcsin+(+(1-x)/(2x))
The right answer for x<0 needs -1 to be multiplied.
https://www.wolframalpha.com/input?i=plot+y=-+sgn(x)+arcsin+(+(1-x)/(2x))
So for x<-1
\int_x^{-1} \frac{dt}{t\sqrt{3t^2+2t-1}}=-\sin^{-1}\frac{1-x}{2x}-\frac{\pi}{2}
for 1/3 <x
\int_{1/3}^x \frac{dt}{t\sqrt{3t^2+2t-1}}=-\sin^{-1}\frac{1-x}{2x}+\frac{\pi}{2}
https://www.wolframalpha.com/input?i=plot+y=-2+arctan+(+\sqrt(3x^2+2x-1)/(3x-1))
So for x<-1
\int_x^{-1} \frac{dt}{t\sqrt{3t^2+2t-1}}=2\tan^{-1}\frac{\sqrt{3x^2+2x-1}}{3x-1}
for 1/3 <x
\int_{1/3}^x \frac{dt}{t\sqrt{3t^2+2t-1}}=-2\tan^{-1}\frac{\sqrt{3x^2+2x-1}}{3x-1}+\pi
https://www.wolframalpha.com/input?i=plot+y=2+arctan+(+\sqrt(3x^2+2x-1)+\sqrt(3)x+)
So for x<-1
\int_x^{-1} \frac{dt}{t\sqrt{3t^2+2t-1}}=-2\tan^{-1}(\sqrt{3x^2+2x-1}+\sqrt{3}x)-\frac{2\pi}{3}
for 1/3 <x
\int_{1/3}^x \frac{dt}{t\sqrt{3t^2+2t-1}}=2\tan^{-1}(\sqrt{3x^2+2x-1}+\sqrt{3}x)-\frac{\pi}{3}
An antiderivative of zero on a disconnected domain is constant on each connected component of the domain. but the constants on different connected components don't have to be equal. Here, the domain of the integrand as a real function is (-\infty, -1) \cup (\frac13,\infty) which is disconnected.
As noted in post #5
For the two different expressions are same we expect the relation
\tan^{-1} (\sqrt{(3x-1)(x+1)}+\sqrt{3}x) + \tan^{-1} \frac{\sqrt{(3x-1)(x+1)}}{3x-1}=-\frac{\pi}{3}
\tan(\tan^{-1} (\sqrt{(3x-1)(x+1)}+\sqrt{3}x) + \tan^{-1} \frac{\sqrt{(3x-1)(x+1)}}{3x-1})=-\sqrt{3}
for x<-1
\tan^{-1} (\sqrt{(3x-1)(x+1)}+\sqrt{3}x) + \tan^{-1} \frac{\sqrt{(3x-1)(x+1)}}{3x-1})=\frac{2\pi}{3}
for x>1/3
They are same. By tan addition law I have checked that it is valid.
  • · Replies 19 ·
