MHB Proving Differentiability of f at $x_0$
  • Thread starter Thread starter mathmari
    Differentiability
The discussion centers on proving the differentiability of a complex function \( f \) at an inner point \( x_0 \) of its domain \( D \). Two equivalent conditions are established: (i) the existence of a limit \( \alpha \in \mathbb{C} \) such that for every \( \epsilon > 0 \), there exists \( \delta > 0 \) ensuring \( |f(x) - f(x_0) - \alpha(x - x_0)| \leq \epsilon |x - x_0| \) for all \( x \) in the neighborhood \( B(x_0, \delta) \); and (ii) the existence of a continuous function \( r \) such that \( f(x) = f(x_0) + \alpha(x - x_0) + r(x)(x - x_0) \) with \( r(x_0) = 0 \). The proof confirms that both conditions are sufficient for differentiability at \( x_0 \).
  • Understanding of complex analysis, specifically limits and continuity.
  • Familiarity with neighborhoods in the complex plane, denoted as \( B(x_0, r) \).
  • Knowledge of the definition of differentiability for complex functions.
  • Ability to manipulate limits and inequalities in mathematical proofs.
  • Study the formal definition of differentiability in complex analysis.
  • Learn about the properties of continuous functions in the context of complex variables.
  • Explore the implications of the limit definition of derivatives in complex functions.
  • Investigate examples of differentiable functions and their corresponding \( r(x) \) terms.
Mathematicians, students of complex analysis, and anyone interested in understanding the conditions for differentiability of complex functions.
mathmari
MHB
Hey! :giggle:
I want to prove the following:
If $x_0$ is an inner point of $D$ ($x_0 \in \text{int } D$), so the differentiability of $f$ at $x_0$ is equivalent to each of the following two conditions.
(i) $\exists \alpha\in \mathbb{C}$ : $\forall \epsilon>0 \ \exists \delta>0\ \forall x\in B(x_0,\delta): \ |f(x)-f(x_0)-\alpha(x-x_0)|\leq \epsilon |x-x_0|$
(ii) There is a $\delta>0$, $\alpha\in \mathbb{C}$ and $r\in B(x_0, \delta)\rightarrow \mathbb{C}$ continuous at $x_0$, $r(x_0)=0$ such that $\forall x\in B(x_0, r): f(x)=f(x_0)+\alpha (x-x_0)+r(x)(x-x_0)$.
The definition is :
Let $D\subset \mathbb{C}$ and let $x_0\in D$ be an inner point of $D$, i.e. $D$ is a neighbourhood of $x_0$, i.e. there is $r>0$ with $B(x_0,r)\subset D$.
Let $f : D \rightarrow \mathbb{C}$.
$f$ is differentiable at $x_0$, if $\displaystyle{\lim_{x\rightarrow x_0}\frac{f(x)-f(x_0)}{x-x_0}}$ exists.
To show (i) to we define as $\alpha$ this limit? :unsure:
Hey mathmari!
That seems as a good approach yes. (Nod)
So the direction $\Rightarrow$ is :
Suppose that $f$ is differentiable at $x_0$. Then $\displaystyle{\lim_{x\rightarrow x_0}\frac{f(x)-f(x_0)}{x-x_0}}$ exists, i.e. there is $\alpha\in \mathbb{C}$ such that $\displaystyle{\lim_{x\rightarrow x_0}\frac{f(x)-f(x_0)}{x-x_0}=\alpha}$, i.e. $\forall \epsilon>0 \ \exists \delta>0\ \forall x\in B(x_0,\delta)$ such that $\left |\frac{f(x)-f(x_0)}{x-x_0}-\alpha\right |\leq \epsilon \Rightarrow \left |f(x)-f(x_0)-\alpha (x-x_0)\right |\leq \epsilon |x-x_0|$.
So we have proven statement (i).
Could you give me a hint for (ii) ? :unsure:
We have $f(x)-f(x_0)-\alpha(x-x_0)=r(x)(x-x_0)$ don't we? 🤔
How do we get that $r(x)$ ? :unsure:
We define it.
Let $r(x)=\frac{f(x)-f(x_0)-\alpha(x-x_0)}{x-x_0}$ and $r(x_0)=0$ on $B(x_0,\delta)$.
Can we prove that $r$ is continuous?
What did continuous mean again? 🤔
We define it.
We have that $$\lim_{x\rightarrow x_0}r(x)=\lim_{x\rightarrow x_0}\frac{f(x)-f(x_0)-\alpha(x-x_0)}{x-x_0}\lim_{x\rightarrow x_0}=\frac{f(x)-f(x_0)}{x-x_0}-\alpha=\alpha-\alpha=0=r(x_0)$$ So $r$ is continuous at $x_0$. :unsure:
That means that we have proven in that way the statement (ii).
As for the other direction, do we have to show that from (i) the differentiability follows and from (ii) the differentiability follows also?
:unsure:
Yep. 🤔
Yep. 🤔
We suppose that (i) holds. Then $ |f(x)-f(x_0)-\alpha(x-x_0)|\leq \epsilon |x-x_0| \Rightarrow \left |\frac{f(x)-f(x_0)-\alpha(x-x_0)}{x-x_0}\right |\leq \epsilon \Rightarrow \left |\frac{f(x)-f(x_0)}{x-x_0}-\alpha\right |\leq \epsilon $.
This is the definition of $\lim_{x\rightarrow x_0}\frac{f(x)-f(x_0)}{x-x_0}=\alpha$, which means that $f$ is differentiable in $x_0$.
We suppose that (ii) holds. Then $ f(x)=f(x_0)+\alpha (x-x_0)+r(x)(x-x_0) \Rightarrow \frac{f(x)-f(x_0)}{x-x_0}=\alpha +r(x)$. Taking the limit we get $\lim_{x\rightarrow x_0}\frac{f(x)-f(x_0)}{x-x_0}=\lim_{x\rightarrow x_0}(\alpha +r(x))=\alpha$, which means that $f$ is differentiable in $x_0$. Is everything correct? :unsure:
Looks correct to me. (Nod)
Great! Thank you very much! (Star)
  • · Replies 38 ·
