MHB Is the Function $f(x,y)=\frac{x}{y}+\frac{y}{x}$ Differentiable and $C^1$?
The function \( f(x,y) = \frac{x}{y} + \frac{y}{x} \) is defined on the domain \( D = \{ (x,y) \in \mathbb{R}^2: x \neq 0 \text{ and } y \neq 0 \} \). Its partial derivatives, \( \frac{\partial f}{\partial x} \) and \( \frac{\partial f}{\partial y} \), are continuous on this domain, indicating that \( f \) is of class \( C^1 \) and thus differentiable. The discussion highlights that differentiability at a point can be established if the partial derivatives exist and are continuous in a neighborhood around that point. It is noted that applying a proposition from a reliable source is often simpler than using the formal definition directly. Overall, the function is confirmed to be differentiable and \( C^1 \) throughout its domain.
evinda
MHB
Hello! (Wave)
Suppose that we want to check if $f(x,y)=\frac{x}{y}+\frac{y}{x}$ is differentiable at each point of its domain and if it is $C^1$.
The domain is $D=\{ (x,y) \in \mathbb{R}^2: x \neq 0 \text{ and } y \neq 0\}$.The partial derivatives :
$$\frac{\partial{f}}{\partial{x}}=\frac{x^2-y^2}{x^2 y} \\ \frac{\partial{f}}{\partial{y}}=\frac{-x^2+y^2}{xy^2}$$
are continuous on $D$. So $f$ is $C^1$ and so it is differentiable.
Does this suffice?
Because there is the following definition:
Let $f: \mathbb{R}^2 \to \mathbb{R}$. We say that $f$ is differentiable in $(x_0, y_0)$, if $\frac{\partial{f}}{\partial{x}}$ and $\frac{\partial{f}}{\partial{y}}$ exist in $(x_0, y_0) $ and
$$\frac{f(x,y)-f(x_0, y_0)- \left[ \frac{\partial{f}}{\partial{x}}(x_0, y_0)\right](x-x_0)-\left[ \frac{\partial{f}}{\partial{y}}(x_0, y_0)\right](y-y_0) }{||(x,y)-(x_0, y_0)||} \to 0$$while $(x,y) \to (x_0, y_0)$.Don't we have to show the latter?
evinda said:
Hello! (Wave)
Does this suffice?
Hi evinda! (Smile)
From wiki:
If all the partial derivatives of a function all exist and are continuous in a neighborhood of a point, then the function must be differentiable at that point, and it is of class $C^1$.
In this case we know that all the partial derivatives of the function all exist and are continuous in a neighborhood of a point, so it's indeed differentiable.
The definition you mention does not require the partial derivatives in a neighborhood, but only at the point itself.
As a consequence there's more to prove, which is implicitly true if we have the partial derivatives in a neighborhood. (Nerd)
I like Serena said:
Hi evinda! (Smile)
From wiki:
In this case, the partial derivatives of the function all exist and are continuous in the domain of the function, right?
So can we consider the domain to be a neighborhood of any possible point $\in \mathbb{R}^2$ ?
What do you mean?
Any point except (0,0). (Thinking)
What do you mean?
What you gave is the definition of differentiability at a point.
We took a proposition from wiki. Applying that proposition is easier than trying to apply the definition directly. (Thinking)
(Nod)
We only apply the definition if we are given a specific point and want to check if the function is differentiable at this point, right?
Also, how else could we show that $f$ is differentiable without showing that it is continuously differentiable?
Right. (Nod)
I'm not aware of another way. (Thinking)
Ok, thank you! (Smile)
  • · Replies 0 ·
  • · Replies 16 ·
