Differential equation dy/dx = 2y-4x
5 replies · 12K views · last reply
nns91
Consider the differential equation dy/dx = 2y-4x
a. Find the value of b for which y=2x+b is a solution to the given differential equation
b.Let g be the function that satisfies the given differential equation with the initial condition g(0)=0. Does the graph of g have a local extremum at the point (0,0) ? If so, is the point a local maximum or minimum
integration, derivative
a. So I choose point (1,0) and plug in y=2x+b and solve for b=1. Then I have y=2x+1. AM I right ? It seems too easy to be right. Is it harder than I thought ?
b. So do I have to integrate ? I found that (0,0) is a critical point. How do I move on ?
For part a) what you need to do is find dy/dx from your given solution and then substitute y in the differential equation and find b. Can you do that?
It would be beneficial to solve the differential equation.
a. Got cha.
b. is g(x)= 2x+1 ? Am I right ? It sounds wrong
nns91 said:
a. Got cha.
Do you know how to solve 1st order DEs of the form
[tex]\frac{dy}{dx}+P(x) y=Q(x)[/tex]
via an integrating factor?
Yeah. so is the integrating factor only e^2 ?
I got the final equation as y=-2x^2. Am I right ?
Also a question about series:
Given a McLauren series: (2x)^n+1 / (n+1)
(a). Find interval of convergence.
So I used ratio test and found that -1/2 <x<1/2. I am testing the end point. At x=1/2, the series will be 1/(n+1) and at x=-1/2, series is (-1)^n+1 / (n+1). How do I prove whether or not they are divergent or convergent. Does 1/ (n+1) converge to 0 ?
