Differential equation homework question
The discussion centers on differentiating the atmospheric pressure equation P=Po e^-h/c, where Po is the pressure at ground level and c is a constant. The user seeks assistance in finding the derivative of this equation with specific values: Po=1.013*10^5 pascals, c=6.05*10^4, and h=1450 meters. The correct approach involves applying the chain rule to differentiate the function, leading to the derivative dp/dh = Po * e^(-h/c) * (-1/c). The user is advised to substitute the given values into this derivative to find the rate of change of pressure with height.
  • Understanding of exponential functions and their derivatives
  • Familiarity with the chain rule in calculus
  • Basic knowledge of atmospheric pressure concepts
  • Ability to perform substitutions in mathematical equations
  • Study the chain rule in calculus for differentiating composite functions
  • Learn about the properties of exponential functions and their derivatives
  • Practice solving differential equations related to physical phenomena
  • Explore applications of atmospheric pressure equations in real-world scenarios
Students studying calculus, particularly those focusing on differential equations, as well as educators and professionals in fields related to atmospheric sciences and physics.
yonathan
can u pls help me with this quaestion?
p=Po e^-h/c
p=Po e^-h/c
Welcome to PF yonathan,
Please post your question exactly as it is stated in your text/homework sheet together with all relevant information and your initial attempts to solve the problem.
Once you have done this, someone will be more than happy to help.
the pressure P of the atmosphere at height 'h' above ground level is given by P=Po e^-h/c where Po is the pressure at ground level and c is the constant.determine the rate of change of pressure with height when Po=1.013*10^5 pascals C=6.05*10^4 at 1450 meters.
i used the for differentiation to differentiate it and find the first derivative of P=Po e^-h/c and i got P=C*Po e^-h or P=Po*(-h/c) e^-h/c and i substitute ted the numbers the given and my calculator seems not to find the ans for it. so can u help me find the derivative of P=Po e^-h/c? pls?
Notice that the two derivatives that you have found are not equivalent:
So, which one is it?
You should also use correct notation: P' instead of P.
the reason put or (where u quoted it at the end of ur message) was to ask u which of the answers i came up with was the correct one.
You want to find \frac{dp}{dh} where c and p_0 are constant. How would you differentiate \frac{d}{dh}(p_0e^{\frac{-h}{c}})?
that was wat i was tyin to find,but i am not sure. i came with the answers i showed u where i added 'or' (the one u put at the end of ur message before this message) and i don't think it is wright, do u think it was right?
what jeffreydk wrote is what i want to figure out exactly, if you can help in that it would be very helpful.
You just need to know how to differentiate e^f(x). What is the derivative of that?
the derivative of e^f(x) is (f)e^f(x) but what if it was e^(F/x) that's what i want to find out??
Are you sure about that?
Simply let:
f(h) = \frac{-h}{c}
Then you have:
P = P_0e^{f(h)}
As above.
so the first derivative of Po e^-h/c is dp/dh=Poe^f(h), where f(h)is -h/c, and after this, all i have to do is substitute the numbers given, yeh? and i am sure about the derivative u asked me.
No it isn't, you need to recheck you derivative. Use the chain rule.
what is 'f' in ur chain rule cause according to it the derivative is f(h)is -h/c??
Note that in this case, h is a variable and not constant. The chain rule states that for a composite function y\left(f(x)\right)
\frac{dy}{dx} = \frac{dy}{df}\frac{df}{dx}
So in your case we have:
P = P_0e^{f(h)}
\frac{d}{dh}P = P_0\frac{df}{dh}e^{f(h)}
Do you follow?
sorry i still don't follow, can u explain it to me in another way or something? i don't know wat to do with the last answer u gave me. do i substitute my numbers on ur answer and wat is e^f(h), how am i suppose to solve it?
Okay, let's take this a term at a time. What is:
\frac{d}{dh}P
What does it represent?
it represents the differentiation of P which is P.
It represents the derivative of P with respect to h, which is not P.
so what is d/dh of e^-h/c
