Differential equation modeling glucose in a patient's body
The discussion focuses on modeling glucose dynamics in the bloodstream using a differential equation. The primary equation is established as Q'(t) = r - kQ(t), which describes the rate of glucose change. Participants clarify that the equation is indeed separable, allowing for integration to solve for Q(t). The correct solution involves incorporating the integration constant related to the initial condition, leading to the final form of Q(t) = (r - (r - kQ(0))e^{-kt})/k. The conversation emphasizes the importance of correctly handling integration constants in differential equations.
ForceBoy
"A hospital patient is fed glucose intravenously (directly to the bloodstream) at a rate of r units per minute. The body removes glucose from the bloodstream at a rate proportional to the amount Q(t) present in the bloodstream at time t. " (Finney; Weir; Giordano, 452)
A) write the differential eq.
B) Solve the diff. eq ##Q(0) = Q_0##
C) find the limit as t goes to infinity
The chapter this problem is found in is one on separable differential equations
The rate at which glucose enters the bloodstream is ##r## units per minute so:
## \frac{dI}{dt} = r ##
The rate at which it leaves the body is:
##\frac {dE}{dt} = -k Q(t) ##
Then the rate at which the glucose in the body changes is:
A) ## Q'(t) = \frac{dI}{dt} + \frac {dE}{dt} = r - k Q(t) ##
I don't see how this is a separable differential equation. I still try to solve it.
##\frac{dQ}{dt} + k Q = r ##
## Q e^{kt} = \int r e^{kt} dt ##
## Q = \frac{r}{e^{kt}}\frac{e^{kx}}{k} ##
B) ## Q(t) = \frac{r}{k} ##
This tells me that the glucose in the bloodstream at any point in time will be a constant. I know this is wrong. It would be appreciated if someone could point me onto the right path to solve this diff. eq. Thank you.
You missed the integration constant which you will need to adapt the solution to the initial condition.
What do you know about separable ODEs? The point of a separable ODE is that you should be able to write it on the form
y'(t) f(y(t)) = g(t).
This is possible in this situation.
y′(t)f(y(t))=g(t).​
Thank you. I put my equation in the form you gave and solved just fine:
## \frac{dQ}{dt} = Q'(t)##
## r - kQ(t) = g(Q(t)) ##
________________________
##Q'(t) = g(Q(t)) ##
## \frac{Q'(t)}{g(Q(t))} =1 ##
## Q'(t) f(Q(t)) = 1##
##\frac{dQ}{dt} \frac{1}{r-kQ} = 1 ##
##\frac{dQ}{r-kQ} = dt ##
##\int\frac{dQ}{r-kQ} = \int dt ##
## \ln|r-kQ | = t +C## (Can't forget the C now, thanks)
## r-kQ = Ae^{t}##
## Q = \frac{r - A e^{t}}{k} ##
If the above is correct, then I can solve the rest of the problem.
Things are OK but a bit verbose up to the line above.
For example, you can go directly from ##\frac{dQ}{dt} = r - kQ## and separate the equation to ##\frac{dQ}{r - kQ} = dt##, and skip several of the lines you wrote.
Mistake in the line above. What is your substitution when you do the integration?
ForceBoy said:
## r-kQ = Ae^{t}##
How about writing like this:
##\displaystyle\int_{0}^{t}dt' = \int_{Q(0)}^{Q(t)}\frac{dQ}{r-kQ} = -\frac{1}{k}\int_{Q(0)}^{Q(t)}\frac{-kdQ}{r-kQ}##
Then you already have the integration constant in terms of the initial condition ##Q(0)##.
Oh, I hadn't caught that! Thanks alot.
Here is the correct version: ## Q(t) = \frac{r-Ae^{-kt}}{k} ##
This is a great tip. Thanks a lot this will save me
work.
## \displaystyle\frac{-1}{k}\int_{Q(0)}^{Q(t)} \frac{-kdQ}{r- kQ} = \int_{0}^{t} dt' ##
## \displaystyle\ln(r-kQ)_{Q(0)}^{Q(t)} = -kt ##
## \displaystyle\frac{r-kQ(t)}{r-kQ(0)} = e^{-kt} ##
##\displaystyle r- kQ(t) = (r-kQ(0))e^{-kt} ##
##\displaystyle Q(t) = \frac{r-(r-kQ(0))e^{-kt}}{k} ##
##\displaystyle Q(t) = \frac{r-re^{-kt}+kQ(0)e^{-kt}}{k} ##
##\displaystyle Q(t) = \frac{r-(r-kQ_{0})e^{-kt}}{k} ##So this last equation must be the answer. Thank you all for your time
You can render the equation separable by changing to ##P = Q- r/k##, so that ##dP/dt +kP = 0## (because, of course, ##dP/dt = dQ/dt##).
The equation was already separable. As demonstrated in #3 by the OP.
