Differential equation on relativistic momentum (ML Boas)
The discussion centers on deriving the distance function from the relativistic momentum equation, specifically using the formula $$p=\gamma m v$$ and the force equation $$F = \frac{md(\gamma v)}{dt}$$. Participants explore the integration of velocity expressed as $$v=\sqrt{\frac{Ft}{m^2+\frac{Ft}{c^2}}}$$ and the subsequent distance equation $$x=\frac{c}{F}\sqrt{m^2c^2 + F^2t^2} + C_1$$, where the constant is determined based on initial conditions. The conversation highlights the importance of correctly squaring terms and integrating to find the relationship between force, velocity, and distance in relativistic contexts.
  • Understanding of relativistic momentum and the Lorentz factor ($$\gamma$$)
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of classical mechanics, particularly Newton's laws of motion
  • Basic understanding of differential equations
  • Study the derivation of the Lorentz factor ($$\gamma$$) in detail
  • Learn integration techniques for functions involving square roots
  • Explore the implications of relativistic effects on force and acceleration
  • Investigate energy conservation in relativistic systems
Students and professionals in physics, particularly those focusing on relativistic mechanics, as well as educators seeking to clarify concepts related to momentum and force in high-velocity contexts.
agnimusayoti
The momentum ##p## of an electron at speed ##v## near the speed ##c## of light increase s according to the formula ##p=\gamma mv##, where ##\gamma = \frac{1}{\sqrt{1-v^2/c^2}}##; m is a constant (mass of an electron). If an electron is subject to a constant force F, Newton's second law describing its motion is: $$\frac{dp}{dt}=\frac{d}{dt} \gamma mv=F$$. Find (a) v(t) and show that v approaches c as t approaches infinite. (b) Find the distance traveled by the electron in time t if it starts from rest.
For ##dy/dx = c##, the solution is $$y=\int {c dx}$$
$$p=\gamma m v$$
$$F = \frac {md (\gamma v}{dt}$$
$$\int{F dt} = \int{md (\gamma v}$$
$$F t= \gamma mv$$
At this step, I don't know how to make v as explicit function of t, since gamma is a function of v too. Thankss
Gee, I think I just have to take quadrat on both sides. Pfft..
Now, I will update what I get and still can't get the distance function.
I get:
$$v^2=\frac{Ft}{m^2+\frac{Ft}{c^2}}$$, then
Writing ##v=\frac{dx}{dt}## gives:
$$\frac{dx}{dt}=\sqrt{\frac{Ft}{m^2+\frac{Ft}{c^2}}}$$
Any suggestion how to determine this integral?
It's easier if you start with the correct expression for v.
I get:
Try again. What does squaring both sides of mv = Ft/\gamma(v) give you?
Shoot. I forget to square Ft. Sorry,
Youre right.
I get this:
$$dx=\frac{cF t}{\sqrt{m^2 c^2 + F^2 t^2}} dt$$
Then, integrating this equation, I get:
Because electron starts from rest, therefore at t=0 x = 0. So, I get ##C_1=-\frac{mc^2}{F}##.
Using this constant, I get the same answer with the solution.
Thanks. Sorry for not being meticulous.
