Optimal Control for Differential Equations with L2 Control Constraint
The discussion focuses on solving a system of differential equations for optimal control with an L2 control constraint. The equations are defined as $y_{1}'=y_1+y_{2}$ and $y_{2}'=y_2+u$, where $u \in L^{2}(0,1)$. The solution involves using the method of variation of parameters to express $y_2(t)$ and $y_1(t)$ in terms of the control function $u$. The final forms of the solutions are $y_2(t)= e^t\int_1^t e^{-z}u(z)dz$ and $y_1(t)= e^t\int_1^t\int_1^s e^{-z}u(z)dz ds$, establishing a clear relationship between the control function and the system's behavior.
  • Understanding of differential equations, particularly first-order linear equations.
  • Familiarity with the method of variation of parameters.
  • Knowledge of optimal control theory and L2 control constraints.
  • Basic linear algebra, specifically matrix representation of systems.
  • Study the method of variation of parameters in detail.
  • Explore optimal control theory, focusing on L2 control constraints.
  • Learn about eigenvalues and eigenvectors in the context of linear systems.
  • Investigate numerical methods for solving differential equations with control inputs.
Mathematicians, control engineers, and students studying optimal control theory who are looking to deepen their understanding of differential equations and control systems.
Alexandru999
To be able to build a control $$
y_{1}{}'=y_1{}+y_{2}
$$y_{2}{}'=y_2{}+u $$
$$u \epsilon L^{2} (0,1)$$
for the care of the appropriate system solution $$y_{1}(0)=y_{2}(0)=0$$
satisfy $$y_{1}(1)=1 ,y_{2}(1)=0$$
Please kindly if you can help me
Discipline is Optimal ControlHELP! i need to find control u
I am not cost functional, how to solve?
I'm not really up on "control" problems and I have no idea what being "cost functional" means but this looks to me like solving a system of differential equations. I am going to write the independent variable as "t".
If you are used to dealing with "control" problems, you might be used to setting a system of differential equations up as a matrix equation. For this problem that would be $\begin{pmatrix}y_1 \\ y_2 \end{pmatrix}'= \begin{pmatrix}1 & 1 \\ 0 & 1 \end{pmatrix}$$\begin{pmatrix}y_1 \\ y_2 \end{pmatrix}$$+ \begin{pmatrix} 0 \\ u \end{pmatrix}$
and then observe that the matrix $\begin{pmatrix}1 & 1 \\ 0 & 1 \end{pmatrix}$ has 1 as a double eigenvalue.
Personally I wouldn't get that "sophisticated". I would, rather, note that the second equation, $y_2'= y_2+ u$ doesn't involve $y_1$ so can be solved directly. The "associated homogeneous equation" is $y_2'= y_2$ which has the general solution $y_2= Ce^t$ for C any constant. Using the "variation of parameters" method, we seek a solution of the form $y_2= v(t)e^t$ (thus "varying the parameter"- letting C be a function). $y_2'= v'e^t+ ve^t= ve^t+ u$ so that $v'e^t= u$, $v'= e^{-t}u$ and $v= \int_1^t e^{-z}u(z)dz$ (I have taken 1 as the lower limit in order to simplify using $y_2(1)= 0$).
So $y_2(t)= Ce^t+ e^t\int_1^t e^{-z}u(z)dz$. Setting t= 1, $y_2(1)= Ce= 0$ so $C= 0$. $y_2(t)= e^t\int_1^t e^{-z}u(z)dz$.
Now turn to the first equation. $y_1'= y_1+ y_2= y_1+ e^t\int_1^t e^{-z}u(z)dz$. The "associated homogeneous equation" for this is $y_1'= y_1$ which has general solution $y_1(t)= De^t$. Again, to use "variation of parameters" we seek a solution of the form $y_1(t)= w(t)e^t$. $y_1'= w'e^t+ we^t= we^t+ e^t\int_1^t e^{-z}u(z)dz$ so $w' e^t= e^t\int_1^t e^{-z}u(z)dz$. $w'(t)= \int_1^z e^{-z}u(z)dz$ and $w(t)= \int_1^t\int_1^s e^{-z}u(z)dz ds$.
Then $y_1(t)= De^t+ e^t\int_1^t\int_1^s e^{-z}u(z)dz ds$.
Since $y_1(1)= D= 0$, $y_1(t)= e^t\int_1^t\int_1^s e^{-z}u(z)dz ds$.
Now that we have solved the differential equations in terms of "u" what would make u a "control"?
  • · Replies 18 ·
