Calculating Paint Usage on a Cube with Differentials
The discussion revolves around calculating the volume of paint used on a cube after applying a 0.02-inch thick coat. The initial attempt using differentials yielded a result of 6 cubic inches, while the correct answer is 12 cubic inches. The discrepancy arose from incorrectly equating the change in edge length (dx) to 0.02 instead of 0.04 inches. After realizing this mistake, the calculations aligned with the expected results. The conversation highlights the importance of accurately determining the differential when applying changes to geometric figures.
Martin Spasov
A coat of paint of thickness 0.02 in is applied to the faces of a cube whose edge is 10 in, thereby producing a slightly larger cube. Use differentials to find approximately the number of cubic inches of paint used. Also find the exact amount used by computing volumes before and after painting.
V = x3
f'(x) = 3x2
dy = f'(x)dx
dy = 3*102*0.02 = 6
However the actual solution is 12 (from the answers). Even when doing it manually :
6 * 102 * 0.02 = 12
When I compute the volume before and after I get the same result as before :
10.023 - 103 = 6.012008
I can clearly see that there is factor of 2 difference, but why ? I used the formula and did not get the solution, what exactly was not ok ?
p.s. first post, if I did something wrong, please point it out :)
V = x3
f'(x) = 3x2
dy = f'(x)dx
dy = 3*102*0.02 = 6
6 * 102 * 0.02 = 12
For sides of length ##x## the total surface area is ##A = 6 x^2##, because there are 6 faces of area ##x^2## each. What is ##dA##?
Likes Martin Spasov
By which amount of ##dx## did you increase an edge?
Likes Martin Spasov and vela
I'm leaving that up to the OP to think about.
Likes Martin Spasov
That's how it was meant. You beat me while I was typing it. But have you noticed that the OP now has solutions in 1,2 and 3 dimensions? Sorry, someone deleted the 3-dimensional one.
Edit: What a pitty. It was a funny situation.
Likes Martin Spasov
Thanks guys, the problem was hat i was equating dx to 0.02 and not to 0.04. Now everything worked out fine :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
