Differentiate e^(-1/2 x) sqrt(1 + 2x) - troubles
  • Thread starter Thread starter jinx007
    Differentiate
14 replies · 3K views
jinx007
the curve y = e^ −1/2x √(1 + 2x) please differentiate this equation i am having some problem.. i want to check my answer
My answer :
e^-1/2x { (1+2x )^-1/2 + (1+2x)^1/2 (-1/2) }
In fact i need to find the x-coordinates and according the booklet the answer of the x-coordinate is 0.5 and me i cannot have the answer ( need to equal the dy/dx = 0 ) to find x-coordinate
Do you need to find the value of x where dy/dx=0? You derived the equation already, put it equal to 0 and solve. As the exponent can not be zero, the factor { (1+2x )^-1/2 + (1+2x)^1/2 (-1/2) }=0.
ehild
differentiation of two products means you must use the product rule.
if y=uv, where u and v are functions of x, such as in your case you have [itex]u=e^{-x/2}[/itex] and [itex]v=(1+2x)^{1/2}[/itex]
then [tex]\frac{dy}{dx}=u\frac{dv}{dx}+v\frac{du}{dx}[/tex]
Ok so what is [tex]\frac{dv}{dx}[/tex] and what is [tex]\frac{du}{dx}[/tex] ?
Solve these separately first and we'll show you if you made any mistakes anywhere in your differentiation.
Okk so for U = e^-1/2x...du/dx = -1/2 e^-1/2x
and for V = (1+2x)^1/2...dv/dx = (1+2x)^-1/2
and i replace in y=uv
Nearly. For [tex]v=(1+2x)^{1/2}[/tex] you need to remember to take the derivative of the inside of the brackets by the chain rule. For [tex]y=[f(x)]^n[/tex], [tex]\frac{dy}{dx}=n[f(x)]^{n-1}.f'(x)[/tex]
And then you replace in [tex]\frac{dy}{dx}=uv'+vu'[/tex] where v' is the derivative of v with respect to x, or [tex]\frac{dv}{dx}[/tex] and similarly for u'.
no i have already evalute,, 1/2 (1+2x) ^-1/2 x 2 = (1 +2x) ^-1/2
ehild
hmmm no let the exponential and x-coordinate part,, help me to differentiate, infact i have differentiate, but i am not obtaining the answer
yeahh infact the x-coordinate of a maximum point
You have differentiate the y(x) function already. Now you have to solve the equation
(1+2x )^-1/2 + (1+2x)^1/2 (-1/2)=0
I rewrite it in tex so as you see more clearly:
[tex]\frac{1}{\sqrt{1+2x}}-\frac{1}{2}\sqrt{1+2x}=0[/tex]
hint: Multiply the equation with (1+2x) ^1/2.
ehild
ehild
Till here i have reached, so
1 / (1+2x)^1/2 = 1/2 (1+2x)^1/2
If i use your hint i get: 0 = 1/2 (1+2X) ^1/2 x (1+2X) ^1/2
Aww now how should i break the brackets ?
## Oppps i think that it is not zero but one
Your last equation is totally wrong. I said multiply the whole equation by
(1+2X) ^1/2. Do it with your first equation, it is correct.
ehild
ehild
so the equation is like this after the multiplication:
1= 1/2 (1+2X)^1/2 X (1+2X) ^1/2
1 = 1/2 (1 + 2x)
is it correct?
by the way the answer that is the x-coordinate is 0.5 according to the booklet
1 = 1/2 (1 + 2x)
is it correct?
Yes, that is correct. And that is a simple linear equation. Solve it for x.
