Differentiating f(r): Solving a Problem
  • Thread starter Thread starter EngnrMatt
    Differential
8 replies · 2K views · last reply
EngnrMatt
The problem I am struggling with is differentiating f(r)=r/sqrt(r^2 + 1)
I rewrote it as: r(r^2 +1)^(-1/2)
Split this up to get:
g(r)=r
h(r)=(r^2 + 1)^(-1/2)
By product rule, f'(r)=gh'+hg'
Obviously
g' = 1
Now by chain rule, I find h'= -r(r^2 + 1)^-(3/2)
Finally, I get f'= [(r^2 + 1)^(-1/2)] - [(r^2)((r^2 + 1)^(-3/2))]
However, Several sources say this is not correct. I followed what I believe to be the right procedures, so any feedback on where I went wrong would be great. I'm doing this from mobile, so I can't show quite as much of my work as I want. Thanks in advance.
EngnrMatt said:
The problem I am struggling with is differentiatingf(x)=r/sqrt(r^2 + 1)
g(x)=r
h(x)=(r^2 + 1)^(-1/2)
By product rule, f'(x)=gh'+hg'
Obviously
g' = 2r
This isn't true.
This is true.
This isn't true (likely because you have the incorrect form of g.
Also, did you mean to write [itex]f(r)=...[/itex] or [itex]f(x)=...[/itex].
If you write
[tex]f(x)=\frac{r}{\sqrt{r^2+1}}[/tex]
then r is a constant, so f'(x)=0.
I meant g' = 1, about to edit it. Everything else was in fact calculated assuming g'=1, it was simply a typing error
If you write
fixed this too. it's f(r)
OK. But please don't edit your posts have there have been replies. It makes the thread difficult to read for future readers. Just make a new post with the corrections.
Anyway:
g(r)=r
Obviously
g' = 1
OK. Looking back at this, I think that it was correct after all. What sources say that it is incorrect??
Solutions in the back of the book, wolframalpha. Apparently the answer is (r^2 +1)^(-3/2)
Your answer is the same as that answer. Try to add up the fractions in
[tex]\frac{1}{\sqrt{r^2 + 1}} - \frac{r^2}{\sqrt{(r^2+1)^3}}[/tex]
Thanks! I didn't think to do that, thank you so much!
