Differentiating with respect to a constant
The discussion centers on the differentiation of integrals with respect to constants, specifically the expression \(\frac{\partial}{\partial \alpha}\int e^{-\alpha x^{2}}dx = -\int x^{2}e^{-\alpha x^{2}}dx\). Participants argue that while \(\alpha\) is treated as a constant, it can also be viewed as a parameter in a multivariable function \(f(x, \alpha)\). The conversation highlights the importance of understanding the roles of variables and constants in mathematical expressions, emphasizing that the designation of \(\alpha\) as a constant is context-dependent and may carry physical significance in certain scenarios.
  • Understanding of partial derivatives and their applications.
  • Familiarity with integral calculus, particularly with respect to parameterized integrals.
  • Basic knowledge of multivariable functions and their differentiation.
  • Concept of constants and variables in mathematical contexts.
  • Explore the concept of differentiation under the integral sign in calculus.
  • Learn about the implications of treating parameters as variables in multivariable calculus.
  • Investigate the physical significance of parameters in mathematical models, particularly in physics.
  • Study the application of the Leibniz rule for differentiating integrals with variable limits.
Mathematicians, physicists, and students of calculus who are interested in the nuances of differentiation with respect to parameters and the implications of treating constants as variables in mathematical expressions.
unchained1978
Quick question on typical integration/differentiation. What is the justification for differentiating some integrals with respect to constants in order to obtain results for them, i.e. \frac{∂}{∂α}\int e^{-αx^{2}}dx=\int-x^{2}e^{-αx^{2}}dx? It seems to me α is a constant, so it seems a little confusing to even talk about the partial derivative. I guess if you treat the entire integral to be a multivariable function of both x and α, f(x,α) then it's somewhat justified, though I could just as well replace alpha with some number and we'd be stuck with something like \frac{∂}{∂8} which seems very sketchy.
... that is exactly what is happening.
... you can say the same about x. There is nothing special about the letter x that says it has to be a variable. It may be that alpha is something like -i p_{x}/\hbar in which case your "constant" has physical significance.
Simon Bridge said:
... that is exactly what is happening. ... you can say the same about x. There is nothing special about the letter x that says it has to be a variable. It may be that alpha is something like -i p_{x}/\hbar in which case your "constant" has physical significance.
The problem I'm having with this though is that x is understood in this sense to be a variable, and therefore \frac{d}{dx} is a measure of how sensitive some function f(x) is to a change in x. But when dealing with partials with respect to constants, this intuitive definition fails, because functions can't change with respect to changes in constants, otherwise they wouldn't be constants! I'm not questioning the mathematical machinery behind this, more so I'm curious as to the reasoning you have to provide when doing so. It seems it would have to go further than simply assuming f to be a multivariate function to differentiate in that sense.
How are you determining that "\alpha" is a constant? In the example you give,
\frac{\partial}{\partial\alpha}\int e^{-\alpha x^2}dx= -\int x^2e^{-\alpha x^2}dx
\alpha is definitely NOT a constant.
What he said: I think you have to give up this idea about what makes a constant and what makes a variable. d/da tells you how the function is sensitive to changes in parameter a. The role a plays in the equation depends on where it came from.
In physics x is usually a parameter representing 1D space, and t is the same for time. But it does not have to be. These letters are just labels for ideas.
In math, x often stands for the parameter of interest in a function and has no special meaning. Others tend to be coefficients and parameters which may or may not be held constant. It is perfectly valid to ask what would happen if a parameter were allowed to vary.
You could as easily write:\frac{\partial}{\partial x}\int e^{-x\alpha^2}d\alpha...
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 19 ·
