Diffraction Grating, calculating rulings/mm from spectrum
To calculate the number of rulings per millimeter for a diffraction grating that spreads the first-order spectrum at angles of 20 degrees for wavelengths 430 nm and 680 nm, the relationship dsin(ø) = my is used, with m set to 1 for the first-order spectrum. The angles ø1 and ø2 can be determined using the arcsine function, but extracting the grating spacing d directly from these equations is not straightforward. A numerical approach is recommended, such as using a spreadsheet to find the value of d that results in the desired angular separation. This method will efficiently yield the required number of rulings per millimeter for the grating.
Oijl
Assume that the limits of the visible spectrum are arbitrarily chosen as 430 and 680 nm. Calculate the number of rulings per millimeter of a grating that will spread the first-order spectrum through an angle of 20.0 degrees.
(y is lambda)
dsinø = my (maxima)
So, the first-order spectrum of white light has a line (maxima) the lowest wavelength and another line at the highest wavelength - right?
And for the first-order spectrum would have a m of 1, right?
If this is true, then,
dsin(ø1) = 430
dsin(ø2) = 680
And, ø2 - ø1 = 20 degrees
And
ø1 = arcsin(430/d)
ø2 = arcsin(680/d)
But, I want to find out d. How can I extract d from these equations?
Or, alternatively, do I not understand what's going on?
You have the right approach, but we can't solve for d explicitly; a numerical approach is needed here. What value of d results in ø1 and ø2 that are 20 degrees apart?
If you can set this up in a spreadsheet, it won't take very long to find d that gives the required 20 degree spread.
