Observing the Effects of Sound Wave Diffraction: A Demonstration Experiment
To demonstrate sound wave diffraction, an experiment can be set up using a speaker, a slit, and a microphone connected to a CRO. Observations should focus on changes in the sound wave's intensity and pattern after passing through the slit, indicating diffraction has occurred. If the sound emerges as a parallel beam without spreading, diffraction is not present. Key results to portray include variations in sound intensity at different angles and the formation of a pattern similar to that seen in multiple-slit experiments. Clear evidence of diffraction can be concluded from these observations.
Faiq
Write an experiment to demonstrate the diffraction of a sound wave and specify what has to observe to conclude that wave has been diffracted
I know that we've to create diffraction by using a speaker and a slit and a microphone connected to a cro. I don't know what is changed after the wave has been diffracted so we can conclude that wave has been diffracted
If there was no diffraction, the sound might emerge from the slit as a parallel beam. But it doesn't.
Hint -- are you familiar with what happens in multiple-slit experiments (with light or sound or other waves)?
http://sciencevault.net/11hscphys/82worldcommunicates/822 Sound.htm
:smile:
I know all the theory but I am asking what results should I portray so I can conclude to an another person the wave has diffracted
  • · Replies 19 ·
