How to Solve the Non-linear Differential Equation in Radial Ink Diffusion?
The discussion focuses on solving a non-linear differential equation related to radial ink diffusion, specifically expressed as d²R/dr² + (2/r)dR/dr - (C/D)R = 0. The method of Separation of Variables is employed, leading to the time-dependent function T(t) = C1e^(C2t). Dimensional analysis reveals that only R²/D has the dimensions of time, confirming it as the correct answer to the posed multiple-choice question.
  • Understanding of non-linear differential equations
  • Familiarity with the method of Separation of Variables
  • Knowledge of dimensional analysis in physics
  • Basic concepts of radial coordinates in spherical systems
  • Study the method of Separation of Variables in differential equations
  • Learn about dimensional analysis techniques in physics
  • Explore solutions to non-linear differential equations
  • Investigate applications of diffusion equations in various fields
Mathematicians, physicists, and engineers dealing with diffusion processes, particularly those focused on solving complex differential equations in spherical coordinates.
tanaygupta2000
The concentration p(r,t) of ink diffusing in water is governed by the diffusion equation
∂p/∂t = D∇^2(p)
where D is a parameter known as diffusion constant. What is the average time taken for a molecule of ink to spread by a root mean square distance R?
(a) √(R/D)
(b) R/√D
(c) R^2 /D
(d) RD
∂p/∂t = D∇^2(p)
I assumed p(r,t) as p(r,t) = R(r)T(t) as Separation of Variables method. I got the expression of T(t) as
T(t) = C1eC2t
and got a non-linear differential equation in R(r) as
d2R/dr2 + (2/r)dR/dr - (C/D)R = 0
(I assumed r to be the radial distance in spherical coordinates)
Now I'm not getting how to solve this differential equation.
You don't need to solve a differential equation to answer this multiple choice question. Only one answer passes the test of dimensional analysis.
Likes etotheipi
R has the dimensions of length and D is a dimensionless quantity.
None of the options give the dimensions of time.
D is not dimensionless. What are its dimensions as per the diffusion equation you posted?
I'm assuming p(r,t) = R(r)T(t).
By this assumption, ∂p/∂t has the dimensions of [LT]/[T] = [L]
and ∇2p(r,t) has the dimensions of [LT]/[L2] = [L-1T]
Hence only R2/D has the dimensions of time, hence the correct answer !
Likes etotheipi
Yes.
Likes tanaygupta2000
