Digamma function and Harmonic numbers
12 replies · 4K views
alyafey22
MHB
Prove the following :
$\displaystyle \psi(n)= -\gamma \,+\,\sum^{n-1}_{k=1}\frac{1}{k}$​
In...
http://www.mathhelpboards.com/f15/difference-equation-tutorial-draft-part-i-426/
... it has been demonstrated that, if $\displaystyle \phi(*)$ is the 'digamma function', then is ...
$\displaystyle \phi(n)= - \gamma + \sum_{k=0}^{n-1} \frac{1}{1+k}$ (1)
The little 'discrepancy' is probably justified from the fact that the definition of digamma function is a little controversial...
Kind regards
$\chi$ $\sigma$
chisigma said:
In...
Kind regards
$\chi$ $\sigma$
Interesting , I will surely read that , thanks a lot ...
chisigma said:
The little 'discrepancy' is probably justified from the fact that the definition of digamma function is a little controversial... $\chi$ $\sigma$
Can you please elaborate on that ?
In...
Digamma Function -- from Wolfram MathWorld
... the digamma function is defined as...
$\displaystyle \psi(x)= \frac{d}{d x} \ln \Gamma(x)$ (1)
... where...
$\displaystyle \Gamma (x)= \int_{0}^{\infty} t^{x-1}\ e^{-t}\ dt$ (2)
... that leads to write, after long efforts...
$\displaystyle \psi(n)= - \gamma + \sum_{k=1}^{n-1} \frac{1}{k}$ (3)
I adopted a slighty different approach defining the digamma function as...
$\displaystyle \phi(x) = \frac{d}{d x} \ln x!$ (4)
... where...
$\displaystyle x!= \int_{0}^{\infty} t^{x}\ e^{-t}\ dt$ (5)
... and after long efforts I arrived to write...
$\displaystyle \phi(n) = - \gamma + \sum_{k=0}^{n-1} \frac{1}{k+1}$ (6)
Of course is a trivial question of definitions...
Kind regards
$\chi$ $\sigma$
chisigma said:
$\displaystyle \psi(x)= - \gamma + \sum_{k=1}^{n-1} \frac{1}{k}$ (3) $\displaystyle \phi(x) = - \gamma + \sum_{k=1}^{n} \frac{1}{k}$ (6)
I assumed you meant $\psi(n)$ and $\phi(n)$ , I know this is correct for all integers but let us try to find $\psi(1)$
From (3) it is $$-\gamma $$ but from (6) it is $$-\gamma+1$$
so which is correct !
I have to confess one 'phobia' of my: I don't like the function $\displaystyle \Gamma (x)$ because any time I meet it I have to do terrible efforts to decide if it is $\displaystyle \Gamma(n)= (n-1)!$ or $\displaystyle \Gamma(n)= (n+1)!$... that's why I prefer the factorial function ...
$\displaystyle x!= \int_{0}^{\infty} t^{x}\ e^{-t}\ dt$ (1)
... that for $\displaystyle x=n$ of course is n!. The conclusion is that a digamma function descending from $\displaystyle \Gamma(x)$ is called $\displaystyle \psi(x)$ and the digamma function descending from $\displaystyle x!$ I called $\phi(x)$ and is...
$\displaystyle \psi(n)= \phi (n-1)$ (2)
Kind regards
$\chi$ $\sigma$
I have never understood the reason for this -1 stuff with the gamma function.
Do you know where it came from?
Reading the wiki article makes it suggestive that it was a bad choice from the start.
On wiki I can see that there is also a pi function introduced by Gauss, that does behave like the factorial function.
Shouldn't that one be preferred over this gamma function?
$$\Pi(n) = \Gamma(n+1) = n!$$
Wiki only states the $\Gamma$ is dominant in literature.
Your question is very useful because permits me to remark an important topic... from my definition of digammma function descends that for x = n is...
$\displaystyle \phi(n) = - \gamma + \sum_{k=0}^{n-1} \frac{1}{k+1}$ (1)
... so that...
$\displaystyle \psi(1) = \phi(0) = - \gamma$ (2)
... which is correct. From the 'standard definition' reported on 'MonsterWolfram' descends that for x=n is...
... so that...
$\displaystyle \psi(1) = - \gamma + \sum_{k=1}^{0} \frac{1}{k} = \infty$ (4)
Gulp! (Tmi)... Kind regards $\chi$ $\sigma$
... so that...
$\displaystyle \psi(1) = \phi(0) = 1 - \gamma$ (2)
... so that...
Wait!
Wolfram says $\psi(1)=-\gamma + H_0 = -\gamma$.
See here.
A sum that has an upper bound below the lower bound is an empty sum.
According to the Weierstrass representation of the gamma function we can get :
$$\psi(x) = -\gamma-\frac{1}{x}+\sum^{\infty}_{n=1}\frac{x}{(n+x)}$$
Now we can put x=1 so we have :
$$\psi(1) = -\gamma-1+\sum^{\infty}_{n=1}\frac{1}{n(n+1)}$$We know that : $$\sum^{\infty}_{n=1}\frac{1}{n(n+1)}=1$$
so $$\psi(1)=-\gamma$$
I described some digamma values http://www.mathhelpboards.com/f10/advanced-integration-techniques-3233/index2.html post #19
I like Serena said:
Wait!
See here.
'MonsterWolfram' sometime seems a little in contradiction with himself... in...
Harmonic Number -- from Wolfram MathWorld
...the following definition of the $\displaystyle H_{n}$ is reported...
$\displaystyle H_{n}= \sum_{k=1}^{n} \frac{1}{k}$ (1)
... and few lines after the $\displaystyle H_{n}$ are defined as the solution of the difference equation...
$\displaystyle H_{n} = H_{n-1} + \frac{1}{n},\ H_{1}=1$ (2)
... so that the element $\displaystyle H_{0}$ is in any case undefined...
Avoiding any type of useless controversial I symply say that the function $\displaystyle \psi(*)$ is, in my opinion, badly defined and leads sometimes to difficulties so that I prefer to use the function $\displaystyle \phi(*)$ that leads to 'secure results'...
My opinion of course...
Kind regards
$\chi$ $\sigma$
Ah well, more specifically it says:
Based on their definition, harmonic numbers satisfy the obvious recurrence equation[TABLE="width: 100%, align: center"]
[TR]
[TD="align: left"]
[/TD]
[TD="width: 3, align: right"](3)[/TD]
[/TR]
[/TABLE]
with
In other words, this is a consequence of the definition - not the definition itself.
The article only says about the definition
A harmonic number is a number of the form
[TR]
[TD="align: left"]
[/TD]
[/TR]
[/TABLE]
arising from truncation of the harmonic series. A harmonic number can be expressed analytically as
[TR]
[TD="align: left"]
[/TD]
[/TR]
[/TABLE]
Then in the article it is extended to more domains.
As I see it, the article doesn't say anything about $H_0$ and it doesn't specifically make it undefined.
It just leaves it sort of hanging.
So the article is a bit sloppy with the definition... and the wiki article is too.
