Dilution process in spectrophometer
  • Thread starter Thread starter Serenie
    Dilution Process
The forum discussion centers on the dilution process in spectrophotometry, particularly in the context of applying Beer-Lambert's Law during neutralization titrations. Participants clarify that while measuring absorbance, the dilution of weak acids or bases can introduce errors due to water's autoionization, which affects concentration. It is established that the primary goal in titration is to detect the endpoint rather than the concentration itself, distinguishing the roles of spectrophotometry and pH indicators in this process.
  • Understanding of Beer-Lambert's Law in spectrophotometry
  • Knowledge of neutralization titration techniques
  • Familiarity with water's autoionization and its effects on concentration
  • Experience with endpoint detection methods, including pH meters and acid-base indicators
  • Research the application of Beer-Lambert's Law in various spectrophotometric analyses
  • Learn about the principles of neutralization titration and endpoint detection
  • Investigate the impact of autoionization on dilution processes in weak acid/base solutions
  • Explore different types of acid-base indicators and their effectiveness in titrations
Chemistry students, laboratory technicians, and researchers involved in analytical chemistry, particularly those focusing on spectrophotometric methods and titration techniques.
Serenie
When using spectrophotometer, to use Rambert-beer's law, we often go through dilution process. Then when measuring neutralization reaction and using week acid or base, then because of water's autoionizaition, i think the results have error.
Is it right?
Chemistry news on Phys.org
The law relies on the idea that absorbance is a linear relationship to concentration. Ideally, linear, and (I believe) the line crosses the concentration-absorbance plot at the origin.
Please elaborate, it is not clear to what you refer here. End point detection of titration, or something else?
Is it right?
After reread and thinking about this again, the description is of two usually very separate things: Spectrophotometer to help measure concentration of some dissolved item which absorbs a specified wavelength of visible light; and neutralization titration between acid and base for which endpoint detection would be either by pH-meter, or acid-base indicator compound. These two ideas are usually not related. Maybe you tell what item is being measured?
What i mean is that when doing neutralization titration, we need to measure the concentration. And i want to measure it by spectrophotometer. But when using spectrophotometer, i often need to go through dilution process. Then, while doing the dilution process in the acid solutiton, the concentration may change because of water's autoionizaition.
So what I'm wondering is whether by doing dilution process, the change in concentration (because of autoionization) is trivial enough to ignore.
i'm sorry about my bad english.
No, we don't need to detect the concentration, we need to detect the endpoint of the titration. These are two different things.
In general the discussion behind is not very different from the discussion of the end point detection when using one- and two- color indicators. Compare http://www.titrations.info/acid-base-titration-end-point-detection
15K
25K
