Dimension of Hilbert Space in Quantum Mechanics
The discussion revolves around the dimensionality of Hilbert space in quantum mechanics, particularly focusing on the relationship between the |x> basis and the energy eigenkets in the context of a particle in a box. Participants explore theoretical implications, definitions, and the nature of these spaces, including the concept of rigged Hilbert spaces.
  • Some participants assert that the Hilbert space of wavefunctions can be spanned by the |x> basis, which is a non-countable set of infinite basis kets.
  • Others argue that the |x> basis does not actually reside in the Hilbert space, suggesting the need to consider rigged Hilbert spaces or Gelfand triples.
  • A participant raises a paradox regarding the cardinality of basis sets, questioning how a countable set of energy eigenkets can span the same space as a non-countable set of |x> basis kets.
  • Another participant proposes redefining the space of wavefunctions for a particle in a box as a different space (space X) that can be spanned by both |x> basis and energy eigenkets.
  • Some participants inquire about the nature of infinite basis kets |x> and their relationship to the eigenkets of the Hamiltonian.
  • One participant suggests using wave packets instead of the position representation, arguing that the position representation is unphysical and that Gaussian wave packets could be a more practical approach.
  • Another participant notes that quantum mechanics has a Hilbert space formulation that does not require non-square-integrable functions, emphasizing the complexity of a mathematically rigorous approach to quantum mechanics.
Participants express differing views on the nature of the |x> basis and its role in Hilbert space, with no consensus reached on the definitions or implications of these concepts. The discussion remains unresolved regarding the relationship between the different basis sets and their cardinalities.
Participants highlight limitations in definitions and assumptions regarding the nature of Hilbert spaces and the applicability of certain mathematical constructs, such as wave packets and rigged Hilbert spaces, without resolving these issues.
vinay uppal
We know that the Hilbert space of wavefunctions can be spanned by the |x> basis which is a non-countable set of infinite basis kets. Now consider the case of a particle in a box. We say that the space can be spanned by the energy eigenkets of the hamiltonian (each eigenket corresponds to an energy eigenvalue). Since the energy eigenvalues are discrete, therefore the set of corresponding eigenkets must form a countable set of infinite kets. But then isn't this a contradiction, since the cardinality of any set of basis vectors spanning the same space must be the same. In other words there must exist a bijective mapping from the one set of basis vectors to another set of basis vectors, whereas in this case we cannot define such a mapping from a countably infinite set to a non-countable infinite set.
This is not a basis for the Hilbert space, since the |x> do not actually live in the Hilbert space. See rigged Hilbert spaces or Gelfand triples.
For another paradox related to this, see
https://www.physicsforums.com/showthread.php?t=122063&highlight=dirac.
Standard quantum mechanic books that have short treatments of rigged Hilbert spaces/Gelfand triples include Nonrelativistic Quantum Mechanics by Anton Z. Capri, Quantum Mechanics: A Modern Development by Leslie Ballentine, and Quantum Mechanics: Foundations and Applications by Arno Bohm. See also the Chapter 14, Bras, kets, and all that sort of thing, in Mathematics for Physics and Physicists by Walter Appel.
A couple of heuristic not so careful posts by me explaining this sort of thing are
http://groups.google.ca/group/sci.physics/msg/48b32de855207a90?dmode=source
http://groups.google.ca/group/sci.physics/msg/4e62f4fa46ef8b73?dmode=source.
As far as I know, almost all (actual) Hilbert spaces used in quantum mechanics are separable, i.e., they have countable orthonormal bases (not to be confused with Hamel bases).
That was an awesome paradox! Too good! And enlightening!
Anyway, returning to my question,I understood your point that |x> does not live in the Hilbert space.Thanks!
Let us not call the space of wavefunctions for a particle in a box as Hilbert space. Let us call it some space (say space X). This space can be spanned by |x> basis and the countably infinite energy basis kets (as in, you can express any wavefunction in |x> basis as well as the energy basis). How is this possible?
what are infinite basis kets |x>? why do they span the same subspace of the L^2 space as the eigenkets of the hamiltonian?
Think of wavefunction space as lying inside the larger space as a proper subset. Anything inside the larger space, including stuff in proper subsets, can be expanded in terms of the generalized eigenstates |x>. Find an orthonormal basis (e.g., energy eigenstates) for the proper subset, in terms of which anything inside the proper subset can be expanded. Stuff outside the proper subset, however, cannot be expanded in terms of a basis of the proper subset.
Hmmm, why not use wave packets? The position representation is unphysical anyway. So, instead of attempting to definine a state corresponding to a particle being located at exactly a certain position using a mathematical tour de force, you can just as well work with Gaussian wave packets. You can cut them off to be exactly zero outside some range using infinitely differentiable functions if you like.
The Fourier transform of Gaussians are Gaussians, so you get wave packets for the momentum eigenstates in the same form.
Yes, I commented on this in the third reference that I gave in post #3,
George Jones said:
Nevertheless, quantum mechanics has a (somewhat) nice Hilbert space formulation (due to Von Neumann) that neither needs nor uses delta functions or any other non-square-integrable beasts (e.g., plane waves).
Two points: many physicists do not want to give up the elegance (and occasional ugliness) of full Dirac notation; quantum mechanics in Hilbert space, done in a mathematically honest way, is itself quite daunting (see, e.g., the books by Reed and Simon).
  • · Replies 16 ·
  • · Replies 61 ·
  • · Replies 59 ·
  • · Replies 67 ·
