Dimension of length using h,G,c
4 replies · 3K views · last reply
Pushoam
Multiple-choice question 25 asking which quantity built from Planck constant h, speed of light c and gravitational constant G has dimension of length. Options: (a) hG/c^2, (b) hG/c^4 marked with a red tick, (c) square root of hc/G, (d) square root of hG/c^5.
[h] = [F r]
##[G] =[ \frac { Fr^2}{m^2} ]
\\ [\frac { hG}c] = [L] ##
So, the answer is option (b).
Is this correct?
  • Multiple-choice question 25 asking which quantity built from Planck constant h, speed of light c and gravitational constant G has dimension of length. Options: (a) hG/c^2, (b) hG/c^4 marked with a red tick, (c) square root of hc/G, (d) square root of hG/c^5.
Mistake: [h ] ## \neq ## [Fr]
[h] = [mv r]
[L] = [ ## \sqrt{ \frac { hG}{c^3}}] ##
Is this correct?
Keep guessing & if we say 'yes' or 'no' you'll eventually hit it, won't you?
So rather than answer 'yes' or 'no' we prefer that you show how you arrived at your answer.
BTW why do you distinguish "r" from "L"? They're the same. For example, [G] =M-1L3T-2 etc. , don't need the "r". In SI (mks) there are only 4 dimensions, to wit, M,L,T and Q. (In cgs there are only the first three).
Pushoam said:
Is this correct?
Yes, but as rude man says your working would be clearer if you were to first reduce all the parameters to the standard set M, L, T... and introduce unknowns for the exponents of tne parameters.
I felt that I could solve the question without converting the dimensions into M,L,T. So, I went that way. I had the impression that that approach is faster. It may be that this impression is wrong.
I think you are suggesting me to do the following way:
I should write dimensions of G, h, c in M,L, T respectively.
And then I should solve the following dimensional equation.
[L] = ##[G]^p[h]^q [c]^r ##
I will get one equation for each dimension. This will give me the values of p,q,r. Thus I will reach the answer.
