Dimensional Analysis: Solving Confusing Steps
Dimensional analysis reveals confusion regarding the number of independent dimensions in the problem, with the correct count being two (M and L) rather than three. The calculation of dimensionless groups indicates that the maximum force per unit area, P/A, is independent of the contact surface area A when using the parameter for compressive strength Y. However, when considering fracture toughness K as a relevant material parameter, P/A becomes dependent on A. The discussion highlights the importance of correctly identifying independent dimensions to avoid errors in dimensional analysis. The thread concludes with the original poster acknowledging a mistake and planning to clarify further in a new post.
promise899
I have a question which has two part described below:
Let the force P to be described by the surface area A between the ice and the buildings. The paramater for ice is comp. str. Y, which has the dimesion of stress. i) Proove the max. force per unit area P/A is independent of A. ii) Ice is a brittle material. That suggest an alternative model, that relevant materia parameter might not be comp stress Y but might instead be fracture toughness K(FL^-3/2). Show that in that case P/A is not independent of A and find how it depends on A?
i )pi(1) = P^X1 * A^Y1 * Y^Z1
I tried to use dimensional analysis, there is variable for part i) m= P,A and Y also parameter is used in analysis is n=3(M,L,T). So m-n=0 number of dimensionless analysis group. I am confused at this step however I did this calculation to reach solution:
i) P=MLT-2 (Ice Force) m-n=4-3=1(number of dimensionless group)
γ =ML-2T-2 (Specific Weight) A=L2 (Contact Surface Area)
pi(1) =( P/A*Y)
How it shows P/A is not dependent of A? I could skip some points in this question also I stuck at part ii. Thanks for help!
Likes Delta2
promise899 said:
Homework Statement:: I have a question which has two part described below:
Relevant Equations:: i )pi(1) = P^X1 * A^Y1 * Y^Z1
This is not correct as T and M are not independent dimensions here (ie, they always appear in the same combination, which is M/T^2). Hence, in this case, n=2.
Force equal to P=ML/T^2 so we use M,L,T . In this way I think n=3
Again, no - you think wrong. M only appears along with 1/T^2. If you know M appears to the power of k in a dimension you know that T will appear to the power -2k. That it also appears with an L in force is irrelevant. You only have two independent dimensions. This is also clear from the simple fact that you can construct a dimensionless quantity.
OP made an error in the question and will do a new post. Thread now locked.
Thanks
Bill
  • · Replies 38 ·
12K
