PeterDonis said:
Sure there are. Geodesics and curvature do not require individual particles to have particular worldlines. They are geometric properties of spacetime itself.
Do you understand what Lorentz invariance is? Do you understand how the Schrödinger Equation is not Lorentz invariant whereas the Dirac equation is?
Yes, Schrödinger Equation uses Newtonian space and time while Dirac equation uses the Minkowski spacetime.
No, it can't. Discarding worldlines for individual particles does not mean discarding geometry. See above.
What topics in SR and GR does this topic fall where I can find the statements "
Geodesics and curvature do not require individual particles to have particular worldlines. They are geometric properties of spacetime itself"? Actually yesterday I tried to find the answer and this is the path I took (or materials I used to research). I went to wiki and saw the following:
And I went to library and tried to reread what I read decade ago that strings where to supposed to handle it. And found the following:
"Einstein's general relativity says no, the fabric of space cannot tear. The equations of general relativity are firmly rooted in Riemannian geometry and, as we noted in the preceding chapter, this is a framework that analyzes distortions in the distance relations between nearby locations in space. In order to speak meaningfully about these distance relations, the underlying mathematical formalism requires that the substrate of space is
smooth—a term with a technical mathematical meaning, but whose everyday usage captures its essence: no creases, no punctures, no separate pieces "stuck" together, and no tears. Were the fabric of space to develop such irregularities, the equations of general relativity would break down, signaling some or other variety of cosmic catastrophe—a disastrous outcome that our apparently well-behaved universe avoids.
"A week or so after I arrived, Witten and I were chatting in the Institute's courtyard, and he asked about my research plans. I told
him about the space-tearing flops and the strategy we were planning to pursue. He lit up upon hearing the ideas, but cautioned that he thought the calculations would be horrendously difficult. He also pointed out a potential weak link in the strategy I described, having to do with some work I had done a few years earlier with Vafa and Warner. The issue be raised turned out to be only tangential to our approach for understanding flops, but it started him thinking about what ultimately turned out to be related and complementary issues.
Aspinwall, Morrison, and I decided to split our calculation in two pieces. At first a natural division might have seemed to involve first extracting the physics associated with the final Calabi-Yau shape from the upper row of Figure 11.5, and then doing the same for the final Calabi-Yau shape from the lower row of Figure 11.5. If the mirror relationship is not shattered by the tear in the upper Calabi-Yau, then these two final Calabi-Yau shapes should yield identical physics, just like the two initial Calabi-Yau shapes from which they evolved. (This way of phrasing the problem avoids doing any of the very difficult calculations involving the upper Calabi-Yau shape just when it tears.) It turns out, though, that calculating the physics associated with the final Calabi-Yau shape in
the upper row is pretty straightforward. The real difficulty in carrying out this program lies in first figuring out the
precise shape of the final Calabi-Yau space in the lower row of Figure 11.5—the putative mirror of the upper Calabi-Yau—and then in extracting
the associated physics."
Is this related to it? That strings where supposed to replace the particles in worldlines by becoming worldsheets? But then Dirac Equation doesn't have strings and I'm just sharing the stuff I'm reading to answer it. What reference can you give that can answer my question as what you said at start :
"Geodesics and curvature do not require individual particles to have particular worldlines. They are geometric properties of spacetime itself."
