Undergrad Dirac Notation for Operators: Ambiguity in Expectation Values?
The discussion centers on the ambiguity in writing expectation values for non-Hermitian operators in Dirac notation. It is clarified that for a linear operator A, the expectation value of A² can be expressed as <ψ|A²|ψ> or <ψ|AA|ψ>, but care must be taken since AA does not equal A†A when A is not Hermitian. Participants emphasize the necessity of calculating intermediate states when dealing with higher powers of A, such as A³. The conversation also touches on the implications of using non-Hermitian operators, noting that they cannot represent physical observables, which raises questions about the validity of calling these expressions "expectation values." Overall, the notation's ambiguity is acknowledged, particularly in the context of non-Hermitian operators.
dyn
Hi
If A is a linear operator but not Hermitian then the expectation value of A2 is written as < ψ | A2| ψ >. Now if i write A2 as AA then i have seen the expectation value written as < ψ | A+A| ψ > but if i only apply the operators to the ket , then could i not write it as < ψ | AA | ψ > ? In other words is the notation slightly ambiguous ?
Thanks
dyn said:
Hi
Thanks
If A is not Hermitian, then ##AA \neq A^{\dagger} A##, so you can't write it that way.
-Dan
I might be confusing myself here but if A is not Hermitian and A2 = AA and A3 = AAA then how do i write the expectation values of these 2 quantities ?
The same way you did in the OP:
##\langle A^2 \rangle = \langle \psi \mid A^2 \mid \psi \rangle \equiv \langle \psi \mid AA \mid \psi \rangle##
You would have to calculate ##\mid \phi \rangle = A \mid \psi \rangle##, then ##\mid \zeta \rangle = A \mid \phi \rangle##, then finally ##\langle \psi \mid \zeta \rangle##.
That's as far as you can go until you specify what the operator A looks like.
-Dan
Likes malawi_glenn and dyn
-Dan
Alternatively, you can calculate
\begin{align*}
\ket{\phi} &= A \ket{\psi} \\
\ket{\chi} &= A^\dagger \ket{\psi} \\
\braket{\psi | A^2 | \psi} &= \braket{\chi| \phi}
\end{align*}
Likes topsquark and malawi_glenn
For a pure state, represented by a normalized vector ##|\Psi \rangle## expectation value is
$$\langle f(\hat{A}) = \langle \Psi|f(\hat{A}) \Psi \rangle=\langle f(\hat{A})^{\dagger} \Psi|\Psi \rangle,$$
for an arbitrary function ##f(\hat{A})##. It doesn't matter whether the operator is self-adjoint or not for the identity of the two expressions. Of course, such an operator cannot represent an observable to begin with, and you might argue that it doesn't make sense to call this expression an "expectation value" in the first place.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 57 ·
