Direct Sum of Vectors in R^4: Determine Which Sums Are Direct and Equal to R^4
The discussion centers on determining which sums of the subspaces U, V, and W in R^4 are direct sums and whether they equal R^4. The initial assertion is that none are direct sums, as U is the only subspace containing the zero vector, affecting the intersections. Clarification is sought on the definitions of direct sums and dimensions, with emphasis on the need for the sum of dimensions to equal the dimension of the combined space. Participants highlight that U, V, and W are subspaces of R^4 and discuss the forms of vectors within each subspace. The conversation ultimately seeks to establish a clearer understanding of the properties and dimensions of these vector spaces.
Jamo1991
In R^4 which of the following sums U+V, U+W and V+W are direct? Give reasons
And which of these sums equal R^4?
U = {(0, a, b, a-b) : a,b ∈ R}
V = {(x, y, z, w) : x=y, z=w}
W = {(x, y, z, w) : x=y}
I put that none are direct sums as U is the only one to contain the zero vector meaning that none of the intersections would also be able to contain the zero vector. Is this right? It seems too simple.
For the second part I am unsure where to start.
Why do you say that V and W do not contain the 0 vector? V is the set of all (x, y, z, w) with x= y, z= w or, more simply with (x, x, z, z). Since x and z can be any numbers take x= z= 0. And why do mention "intersections"? This question is about direct sums, not intersections.
What is the definition of direct sum?
Yes, U+ V is a direct sum. That means that the dimension of U+V is the dimension of U plus the dimension of V. What are those?
Notice that any vector in U is of the form (0, a, b, a-b)= (0, a, 0, a)+ (0, 0, b, -b) and that any vector in V is of the form (a, a, b, b)= (a, a, 0, 0)+ (0, 0, b, b).
No, the dimensions are NOT 4. Do you really understand what "dimension" means? U, V, and W are all subspaces of R^4. Can you give a basis for each vector space?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
