Direction and magnitude of the current
4 replies · 11K views
zooropa
Taking R = 1.00 kΩ and ε = 250 V in the figure, determine the direction and magnitude of the current in the horizontal wire between a and e.
http://img5.imageshack.us/img5/7250/img001nkm.th.jpg
Kirchhoff´s law
I must try to apply Kirchhoff´s loop rule to both rules?
Yes, all three loops. Or perhaps you could combine the 4R and 3R in parallel to get a simpler circuit with only two loops. Once you know I1 and I2, it should be easy to find I in the original circuit.
I think it will be done with 4R and 3R in parallel. But how can i have the value of the new R?
If i have the new value of R i could find I1 and I2, like this:
(xR)I1+(yR)I2=250
and
(xR)I1+(yR)I2=500
I think it will be the solution, but the problem is that i can't find the new value of x and y if i combine the 4R and 3R in parallel to get a simpler circuit with only two loops.
Any help? Thanks
The 4R and 3R (4000 and 3000 ohms) are in parallel. You must use the formula for the resistance of two resistors in parallel.
I don't understand what your x and y represent.
It seems to me the current through the combined resistors would be I1 + I2, so the equations will each have one more term than you have shown.
