Discern initial V w/o components?
5 replies · 2K views · last reply
afronicus
Discern initial V w/o components!?
Ok, ball traveled 188m (618 ft) before landing on the ground. Assume ground is flat, and ball Vi is from 45o, disregard air resistance, and Starting position is .9m above ground.
Find Vi
I KNOW )))) a= 9.8 m/s2
Xi= 0
Xf=183
Yi= 0.9m
ANGLE= 450
Vy (@ highest point) = 0
Ok so the equations I'm using are:
A---Vf= Vi + (a)(t)
B---Xf= Xi+ Vi+ (1/2)(a)(t)2
C---(Vf)2=(Vi)2+2a(Xf-Xi)
D---Xf-Xi=((Vi+Vf)/2)(t)
So I've been racking my brain over this for the past hour, and I keep failing to discover the answer. My equations are left with 2 variables. What am I missing?? :/
Find Vi
I think you've overloaded your brain with information and equations, so let's take it slowly.
Split the initial velocity Vi acting at 45°, into x and y components.
The first line says
So this means it traveled horizontally 188 m. So what does this tell you about the time taken for the motion? (Hint: horizontal velocity remains constant throughout, so distance = speed*time)
Write the time,t, in terms of Vi.
When you get this, then we will consider vertical motion.
hi, thanks a bunch for your reply. Ok, so my Vi in components is Vix=Vi cos(45)
Viy=Visin(45)
Ok, and time can be written as:
t =( Vfx/y / a) + Vi[SUB]x/y[SUB].
(V[SUB]x[SUB])(t)=188 m
apparently there is numerical value you're supposed to get...I opted to have Mastering Physics show me the answer, said it was 41.3. I just can't figure out how.
A man, my formula B is off, initial veloss should be multiplied by time. Thought I had figured out out... Not so much.
afronicus said:
(Vx)(t)=188 m
So your time would be
[tex]t = \frac{188}{V_i cos 45}[/tex]
I can't really read how you manipulated formula B, but considering y-direction, the initial displacement y0 you were given. And you know that y = 0 when t = 188/(Vicos45°).
Just plug it in and solve for Vi.
