Discover the Energy-Efficient Process of Liquifying Oxygen for Power Generation
  • Context: Undergrad
  • Thread starter Thread starter Derceritus
    Cooling
The discussion revolves around the feasibility of using liquefied oxygen as a means of power generation, specifically exploring the energy requirements for liquefaction and the potential for energy recovery when the oxygen returns to gas. Participants examine the implications of thermodynamics and energy conservation in this context.
  • One participant inquires about the electricity required to liquefy oxygen and proposes a system that could potentially generate power by using the pressure from returning gas to turn a turbine.
  • Another participant asserts that, according to the first law of thermodynamics, it is impossible for the system to output more energy than is input, emphasizing energy conservation.
  • Further contributions reiterate that energy losses will always result in less energy output than input, regardless of the energy source used to return the oxygen to gas.
  • One participant suggests that using ambient heat from the environment could aid in the process, but still maintains that energy output cannot exceed energy input.
  • A later reply compares the proposed system to a steam cycle, noting that while it may utilize ambient heat, it cannot produce more work than the energy put into the liquefaction process.
  • Another participant draws parallels to air conditioning systems, explaining that while they operate on similar principles, they do not produce energy and are costly to run, highlighting the limitations of such systems.
  • A brief comment questions the need for a heat sink in the proposed process.
Participants generally agree on the principles of thermodynamics and energy conservation, but there remains disagreement regarding the potential for energy recovery and the feasibility of the proposed system. The discussion does not reach a consensus on the viability of using liquefied oxygen for power generation.
Participants acknowledge various assumptions about energy losses, the efficiency of the proposed system, and the role of ambient heat, but these aspects remain unresolved within the discussion.
Derceritus
How much electricity does it take to liquify oxygen? I am just curious as if it only took small amounts one could create a power plant that liquified oxygen, put it in a small chamber outside to return it to a gas and used the pressure to turn a turbine with the gas returning for cooling. This of coarse would only work if it put out more energy then it took in.
Welcome to PF.
If the oxygen is to return to its original state, it is impossible for it to put out more energy than is put in. This is known as the first law of thermodynamics, which essentially says that energy is conserved.
Redbelly98 said:
Welcome to PF.
Actually it gets the energy to return to gas from the sun. That is why the tank for the liquid oxygen would be outside, to take the heat from the outside air, which anywhere in the world is warm enough.
It doesn't matter where it gets the energy to return to the gas phase. The energy into the system will always be less than the energy you can get back out of it--less because of losses. If if you could magically remove all sources of loss, the energy out still cannot be more than the energy in.
It sounds like you are saying that out of habit. If you just liquified oxygen in a chamber, let it return to a gas and had it go through a turbine, I would agree, you would lose energy. However if you put that liquid oxygen in a smaller chamber, one only as big as the liquid, it would have greater pressure when it returned to a gas. I am not saying that your are not right, one may get less electricity out of this system if the cooling takes too much, but if it only takes small amounts to get it going, you could make a lot of energy.
I see what you are saying.
Your idea is that you use energy to liquefy a gas (O2 in your example), and then use ambient heat to expand it, doing work. Then, remove heat from expanded gas, and continue.
This really isn't anything new though; it is essentially a steam cycle except it uses a working fluid much more volatile than water, and uses ambient heat/solar power as a heating source instead of a more conventional fuel source (nuclear, coal, etc.).
It will NEVER be able to produce more work than is put in as energy, but there is no rule that says it can't produce more energy than YOU put in as work (in this case, the liquefaction process and pump required to keep the liquid flowing).
This is similar to how, from the point of view of work/energy put in, an oil rig produces huge quantities of energy. All you have to do is pump the crude oil up; the biochemical processes that guided its formation already happened, free of charge. This is similar to using the sun; an extant free energy source.
Your process MAY work, but the amount of work produced will not exceed the difference between the gas in its highest enthalphy state minus its lowest. (I think...correct me if I am wrong, anyone, but I believe this is technically accurate.)
That process is basically exactly how an air conditioner works. A gas is compressed and liquefied, then pumped into an area that you want to cool, a fan is there to blow ambient air over the liquid and transfer heat into it and then the gas is pumped back to an area where it can be compressed again. They of course are quite costly to run, and definitely don't produce energy, even though the heat taken in by the refrigerant would cause it do to work, it is nowhere near enough to regain anything more than a fraction of the energy put into producing the liquid phase.
I don't want to discourage from thinking of stuff like this. If you had come up with this idea for unlimited energy before refrigerators and air conditioners were invented, and tested it out, you would have failed to produce unlimited energy, but you would be sitting on a gold mine of an invention anyway.
dont u need a sink
  • · Replies 32 ·
  • · Replies 56 ·
  • · Replies 38 ·
  • · Replies 87 ·
