Discrete Math Problem : Mathematical Induction
The discussion revolves around proving a formula involving the sum of harmonic numbers, specifically H1 + H2 + ... + Hn = (n + 1)(Hn - n). The subject area is discrete mathematics, focusing on mathematical induction and properties of harmonic numbers.
  • Participants discuss the validity of the formula for n = 1 and explore the definition of harmonic numbers. There is uncertainty regarding the correct expression for Hn, with conflicting statements about its value.
The discussion is ongoing, with participants questioning the correctness of the initial formula and its implications. Some participants suggest that if the formula does not hold for n = 1, it may not be valid at all.
There is confusion regarding the definition of harmonic numbers, with participants noting that there may not be a simple formula for Hn. This uncertainty affects the ability to prove the original statement.
GoGoDancer12
Prove that H1 +H2 +...+Hn = (n +1)(Hn-n)?
Hn denotes the nth harmonic number.
The nth harmonic number is the sum of 1+1/2+...1/n,
which is n / n +1.
I'm not really sure if Hn = (1/ n) .
Prove by Mathematical Induction
Basis Step : P(1) = Hn = (n +1)(Hn-n)
(1 / n) = (n +1) ( (1 / n) -n)
(1) = ( 1 + 1) (1-1)
1 = (2) (0)
1 = 0, which is false
or
Basis Step:
P(1) = Hn = Hn = (n +1)(Hn-n)
( n / n + 1) = (n + 1) ( (n / n + 1) -1)
P(1) is false, because 1/ 2 does not equal to - 1
which is n / n +1.
Well, it can't be both [itex]n/(n+1)[/itex] and [itex]1/n[/itex]. In fact, I don't think it is either one. As far as I know, there is no simple formula for [itex]H_n[/itex].
Let's start with the induction hypothesis. Namely, we need to check that the formula is correct for [itex]n = 1[/itex]. Plugging in [itex]n = 1[/itex], the formula reduces to
[tex]H_1 = (1 + 1)(H_1 - 1)[/tex]
Is this correct?
How would I know if its correct or not if there is no simple formula for H_n ??
There may not be a simple formula for [itex]H_n[/itex] in general, but what's [itex]H_1[/itex]? Isn't it simply 1? (Look at the defining sum.)
I think H1= (1 / n) = 1
Right, so is the formula correct for [itex]n = 1[/itex]? i.e. is it true that
[tex]H_1 = (1+1)(H_1 - 1)[/tex]
If not, then there is something wrong with the problem statement.
No, its not true because Hn = 1
and (1+1)(1-1) = 0
So, there's no way to prove H1 +H2+...+Hn = (n +1) (Hn - n)
is true, right??
and (1+1)(1-1) = 0
is true, right??
Correct. If it isn't even true for [itex]n = 1[/itex] then it's certainly not a valid formula.
  • · Replies 22 ·
  • · Replies 23 ·
