[Discrete math] Proving the form of a function
The discussion centers on a problem in discrete mathematics involving the function f(x1, x2, x3) = x1x2 v x2x3 v x1x3, with the goal of proving that f(x1, x2, x3) equals x2. Participants express confusion over how to manipulate the function to arrive at the desired result and question whether the problem statement is accurate. Truth tables are referenced as a method to verify the function's outputs, but discrepancies lead to doubts about the correctness of the original claim. Ultimately, it is suggested that the statement to be proven is indeed incorrect, as demonstrated by specific evaluations of the function.
fawk3s
I wasnt really sure where I was supposed to post this problem, so I figured this place is as good as any.
x2 - the inversion of x2. (Yes, I was too dumb to figure out how to get "_" on it.)
We are given that
f(x1,x2,x3) = x1x2 v x2x3 v x1x3 = x1&x2 v x2&x3 v x1&x3
Prove, that
f(x1,x2,x3) = x2
Well I tried replacing x2 with x2, but I don't really know how that changes anything. I have no idea how you are supposed to end up with x2. And even when trying to replace the x'es with 0's and 1's, I DO NOT get that
x1x2 v x2x3 v x1x3=x2
that is
f(x1,x2,x3) = x2
Am I doing this whole thing wrong? Because it doesn't make much sense to me.
We are given that
Prove, that
f(x1,x2,x3) = x2
that is
f(x1,x2,x3) = x2
Just to make typing simpler, you could dispense with the subscripts and use A, B, and C. Also, there are other notations for the negation of something, such as ~A or A'.
So your function can be written as f(A, B, C) = AB + BC + AC, and you are to show that f(A, ~B, C) = B. (Here + means "or" and a product means "and".)
I made columns for A, ~B, and C and filled in the eight rows of the truth table. I added columns for A(~B), ~BC, and AC, and then one more column for A(~B) + ~BC + AC. The truth values in the last column are different from those of B, so I'm wondering if there's an error in the problem or that you might have copied it down wrong.
No, its copied down right. After trying to crack it and simplify it for a while (which I now realize was stupid because it's in its simplest form...), I made the truth table as well and saw that B doesn't match the new function's values. After that I was sure that either I was doing something totally wrong or there had to be an error in it. So I guess it was the ladder this time.
Thank you.
Just don't walk under that ladder - it's bad luck.:-p
(The word you want is "latter".)
We are given that
Prove, that
f(x1,x2,x3) = x2
that is
f(x1,x2,x3) = x2
The result you are asked to show is incorrect. We have
f(0,x_2,0) = 0 \vee 0 \vee 0 = 0, \text{ for any value of }x_2,\\<br /> f(1,x_2,1) = x_2 \vee x_2 \vee 1 = 1 \text{ for any value of }x_2.<br />
RGV
I think it's too late to edit now :biggrin:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
