Discrete modes of vibration for sonometers
Discrete modes of vibration in sonometers arise from standing waves, which require nodes at both ends, allowing only specific wavelengths that satisfy the equation 2L/n, where n is an integer. The wire's length determines these wavelengths, while the wave's frequency is influenced by the tension and mass per unit length of the wire. Higher tension increases wave speed due to greater restoring forces between adjacent atoms, while increased mass slows the waves due to higher inertia. Placing a finger in the middle of the wire alters its effective length and can discourage certain standing waves from forming. While only discrete modes are recognized as stable, non-discrete vibrations can occur but are less identifiable.
T7
Hi,
I have a few questions about Sonometers which I've attempted to think through - though I may be missing something. Perhaps someone can fill in any gaps for me?
If I was to be asked why only 'discrete modes' of vibration can exist for a sonometer, is it enough merely to talk about the fact that this involves standing waves, and for a standing wave you must have "nodes" at either end, and that this is only possible for wavelengths that satisfy 2L/n (where n is an integer), and consequently only possible for frequencies that satisfy vn/2L?
As I understand it, what determines the wavelengths is simply the length of the wire we provide. The frequency, on the other hand, is also a function of the velocity of the wave, and this in turn is dependent on the tension of the wire and its mass per unit length. [I believe waves travel faster on a tighter string (but why?), and slower on a more massive string (which seems fairly obvious).] So finding the 'resonant frequency' is a bit more complicated, since it isn't just dependent on the wavelengths that the wire will permit, is it?
Another question I have is this: if I was to place my finger lightly in the middle of the wire, would I be, in effect, altering the length of the wire, or merely encouraging a standing wave with a node in that position (eg. the second harmonic) to form?
Only discrete modes can exist because of the standing wave pattern that quickly picks up once a vibration occurs. Any other frequency will be quick to die out. In practice, some frequencies close to these permitted modes will also exist.
Waves travel faster in a string with higher tension because the solution to the string equation says so. In a more layman explanation, you can see that a tighter string the higher the force between adjacent atoms, thus when one moves, it affects the ones beside it with greater influence, leading to what appears to be faster wave motion. As for massive (as in high linear density), again the string equation solution says so, but you can think of it as having more inertia.
If you place your finger in the middle of the wire, you will be altering the nature of the wire, that is the effective length. Different lengths support different modes.
Thanks mezarashi.
tighter wire has a greater (transverse Force component) restoring force
when displaced from equilibrium (straight) position.
Gently touching the middle of the string with a finger will DIScourage
standing waves that have displacement there.
Careful - some sonometers have standing waves with node on one end, antinode on the other. Strings can be set up to have anti-nodes at BOTH ends.
Finally, I'd say that even non-discrete vibrations CAN exist, but will not be recognized as "modes" - and are difficult to recognize at later times, since (by definition) they do not look the same on each reflection.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
