What is a discrete-space derivative?
  • Thread starter Thread starter WhiteRae
    Derivative
A discrete-space derivative is a generalization of the continuous derivative, applicable when the variable takes on discrete values. In a discrete space, the derivative can be expressed as the difference between function values at equally spaced intervals, typically represented as f(x+δx) - f(x) divided by δx. For natural numbers, this simplifies to f(x+1) - f(x), where the smallest difference is 1. Understanding this concept may require familiarity with the gamma function, which relates to factorials and can be complex for those at a calculus II level. The relevance of a discrete-space derivative ultimately depends on the specific context of the problem being addressed.
WhiteRae
I was looking up how to find the derivative of a factorial and found this thread:
https://www.physicsforums.com/showthread.php?t=1328
What is a discrete-space derivative? I tried looking it up, but had no luck. If someone could explain it in a way someone in calc 2 could understand that would be great, or at least point me in the direction of more information.
A discrete space is a space where all subsets are open. I have never heard of a discrete space derivative, however.
Have you heard of the gamma function? http://en.wikipedia.org/wiki/Gamma_function
Take a look at how it relates to the factorial function. It does take a lot of work to understand if you're only at the first year level in math.
I was looking at the Gamma Function. I understood it a little bit, but in general it was way over my head.
The general idea is that the more familiar continuous space derivative,
\frac{df}{dx}=\lim_{\Delta x\to 0}\frac{f(x+\Delta x)-f(x)}{\Delta x}
Can be generalized in cases where the smallest possible difference between two different values of a discrete variable x is a constant (in other words, all elements of the set are equally spaced) \delta x according to the equation
\frac{df}{dx}=\frac{f(x+\delta x)-f(x)}{\delta x}
(For a continuous space, \delta x is infinitesimally small)
If x is only allowed to be a natural number, then the smallest diffence between two different values of x is 1, and so
\frac{df}{dx}=f(x+1)-f(x)
Whether or not this is really the type of derivative you are interested in depends on the context of your problem.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
