Displacement of ball bearing using conservation of energy
The discussion centers on the derivation of the displacement equation D² = 4hL for a ball bearing released from a pendulum setup. The ball is initially held at height h and, upon release, falls a vertical distance L while traveling horizontally a distance D. The relationship between these variables is established through conservation of energy principles, specifically equating potential energy (mgh) to kinetic energy (1/2 mv²). The horizontal motion of the ball is influenced by the time it takes to fall, which is affected by both h and L.
  • Understanding of conservation of energy principles in physics
  • Familiarity with projectile motion concepts
  • Knowledge of basic kinematics equations
  • Ability to manipulate algebraic equations
  • Study the derivation of projectile motion equations in physics
  • Learn about the conservation of energy in mechanical systems
  • Explore the effects of time on horizontal displacement in projectile motion
  • Investigate the relationship between height and horizontal distance in free-fall scenarios
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of projectile motion and energy principles.
phosgene
A large ball bearing is suspended as a pendulum. One end of the pendulum is held by the electromagnet (1) and the ball is initially held by magnet (2) at some height, h, above its lowest position. The ball is released from (2) and as the pendulum swings through the vertical, the ball cuts an infrared beam (3) and causes the electromagnet holding the string (1) to release it. Ideally, the string is released at the instant the ball cuts the infrared beam. The ball then falls a height L and travels a horizontal distance D from the point of release.
The final displacement (D) of the ball from the release point can be determined using:
D^2=4hL
I can't figure out how this was derived.
Potential energy = mgh
Kinetic energy = \frac{1}{2}mv^2
I really have no idea. I thought that the final displacement from the release point would be dependent only on h, as the force of gravity after release is only acting downwards, so the horizontal velocity wouldn't change. I've also tried 'reverse-engineering' the equation to figure out how it was derived, but I don't understand where the L*h value came from, as the final kinetic energy should be mg(L+h).
The velocity of the ball is horizontal at point 3 and you get it from conservation of energy. mgh=1/2 m v^2. After reaching point 3, the ball is a projectile.
ehild
Try the solution in two steps.
a) falling through h
b) falling through L.
Ok, horizontal velocity doesn't depend on L, but what if L is very big, let's say 1 mile ?
The ball takes "a lot of" time before touching the ground and during that time it moves horizontally as well.
Yes it does..So where's the problem?
  • · Replies 32 ·
