Dissolved in solution automatically mean disassociation?
  • Thread starter Thread starter instantresults
    Mean
Dissolution of ionic compounds like Na2CO3 in water typically leads to dissociation into their respective ions, which is a common assumption in chemistry. In the discussed scenario, when Na2CO3 reacts with HCl, it produces carbon dioxide gas, confirming the expected reaction of carbonates with acids. The participant questions the automatic assumption of dissociation and notes that not all substances, such as glucose, dissociate when dissolved. However, carbon monoxide is unlikely to form in this reaction due to the specific conditions and typical behavior of carbonates. Overall, the discussion emphasizes the standard behavior of salts in solution and the expected gas evolution from acid-carbonate reactions.
instantresults
a 6.57g sample of NiSO4*6H2O (molar mass 262.84) is dissolved in enough water to make 50.00mL of a green solution and 7.15g of Na2CO3*10H2O (molar mass 286.14) is dissolved in enough water to make 50.00mL of a colorless solution. The two solutions are mixed and a green precipitate forms. The resulting slurry is divided into two equal portions. To one portion is added an excess of 6M HCl, which results in the disappearance of the precipitate and a rapid evolution of a gas. To the second portion is added a few milliliters of 6M NH3. The precipitate dissolves and a blue solution forms.
Q: according to the info in the passage the gas that evolves is
1) sulfur dioxide
2) sulfur trioxide
3) carbon dioxide
4) carbon monoxide
The solution says that HCl reacts with CO32- to form CO2 gas.
I don't understand why they assume that Na2CO3 dissassociates into its respective ions when dissolved in water (or is the word "dissolved" automatically mean the molecule has separated?). ALso what's to stop carbon monoxide from forming? Thanks for any help
Not everything dissociates when dissolved - for example dissolved glucose doesn't. But most salts do.
I can't think of a reaction that would produce carbon monoxide in these conditions. Carbonates reacting with acid always behave the same way.
10K
  • · Replies 19 ·
11K
