Dissolving silver
  • Thread starter Thread starter ldanielrosa
The discussion revolves around the process of refining silver from scrap using nitric acid, specifically focusing on minimizing the loss of acid during the reaction and exploring the optimal conditions for dissolution. Participants discuss various methods, chemical reactions involved, and the practicality of the refining process.
  • Experimental/applied
  • One participant seeks to understand how dilute nitric acid must be to allow for the redissolution of NO2 into nitric acid, aiming to reduce acid loss during the refining process.
  • Another participant suggests that cold dilute acid produces NO, which can then react with oxygen to form NO2, while hot concentrated acid produces NO2 directly, leading to different yields of nitric acid.
  • A third participant notes the complexity of the system, mentioning that multiple competing reactions occur simultaneously, and emphasizes the need for experimental comparison to find optimal conditions.
  • One participant questions the necessity of refining silver, pointing out that silver is relatively inexpensive and suggesting alternative methods for dealing with scrap materials.
  • Another participant expresses confidence in the cost-effectiveness of isolating silver from scrap compared to the expenses of chemicals and tools, despite acknowledging the challenges in minimizing losses.
  • A warning is issued regarding the disposal of silver compounds, highlighting their toxicity to the environment.
Participants express differing views on the practicality and cost-effectiveness of refining silver from scrap, with some questioning the effort involved while others defend the process. There is no consensus on the optimal method or conditions for dissolving silver.
The discussion highlights the complexity of chemical reactions involved in the refining process and the various factors that can influence yields, such as temperature and concentration. Specific assumptions about costs and safety measures are also present but not universally agreed upon.
This discussion may be of interest to hobbyists in metal refining, chemists exploring reaction dynamics, and individuals considering the environmental impact of chemical disposal.
ldanielrosa
TL;DR
How dilute must it be to avoid destroying half the acid?
I'm making poor man's nitric acid to refine silver from scrap. I would like to waste as little as possible. I've noticed that about half the acid is destroyed oxidizing the metals, and I'd like to reduce that if possible. One reference mentioned that I lose only one in four in a "dilute solution" instead of half. How dilute must it be to allow the NO2 to disproportionate so that half of it will redissolve and become nitric acid again?
Chemistry news on Phys.org
Cold dilute acid will react to produce NO (reacts with oxygen to make NO2)
Hot concentrated will react to give NO2
NO2 will disolve in water SPARINGLY to produce a weak nitric acid ...
Probably safer to go with cold weak acid , catch the NO gas (clear) in a large container , add air to make it NO2 (brown) , add water and shake ... don't expect much yield.
This system is rather messy, there are several competing reactions occurring in parallel and difficult to control separately, although some of them prefer higher/lower temperatures, some occur easily in higher/lover concentrations. The only sure way of finding optimal point is experimental comparison of yields varying temp and concentration.
Quick googling found this patent: https://patents.google.com/patent/WO2017009667A1/en so you are definitely not the first one to think about optimizing the process.
Are you refining silver for purposes other than exploring science? Silver, unlikely gold, is actually fairly cheap and refining silver, even from scrap, does not offset the costs of whatever chemicals and tools you will need to achieve that.
That said, if you are doing it for fun, why are you trying to dissolve the silver instead of everything else? Plastics can be burnt (with proper safety measures and knowledge of local legislation) and sometimes dissolved in organic solcents. Metals less 'noble' than silver and copper will readily dissolve in HCl, which is typically available in hardware stores. Does produce hydrogen though, so be careful!
Thank you oz93666 and Borek. I see that minimizing losses will not be trivial.
Thank you Mayhem for your concern on the financial side, but I don't quite agree with your calculations. I am reasonable confident that it will be an order of magnitude less expensive for me to isolate my own silver from the scrap I have on hand.
That said, I appreciate having other minds to benefit from on this. Thank you all for your time.
Also just to mention that silver compounds should not be put into the drainage system as it is very toxic to plants and animals.
  • · Replies 16 ·
  • · Replies 19 ·
10K
