Distance a bullet will travel while shot underwater
1 reply · 4K views
Wanna_be_Feynman
hey
I am trying to work out the problem:
If I shoot an ak47 underwater with 7.62x39mm ammunition, how far will the bullet travel before coming to a stop?
The equation that I have used to find the drag force is the drag equation:
F =1/2 p*A*C_d*v^2
where:
p is the density of the water (1000 kg/m^3)
v is the velocity of the bullet (730 m/s)
A is the cross sectional area of the bullet with diameter 7.62mm
C_d is the drag coefficient to which I am using 0.29 based from a website which had statistics about the bullet
I have found this I get approximately 850, 000 N of force. I am then stuck as to how to calculate the distance the bullet travels before it stops.
Because the drag force varies with velocity, you will get a differential equation in ##v##. The drag force will not be constant. The first step is to derive this differential equation.
